    Workspace with Monospaced Fonts
    2 Posts 2 Posters 957 Views 1 Watching
    • P Offline
      ptrstack
      I’m compiling Notepad++ with a few minor customizations.
      How difficult is it to make the folder tree that displays when using a folder as a workspace display in monospaced fonts?
        Ekopalypse @ptrstack
        @ptrstack
        How difficult is it to make the folder tree …
        depends on how complex you want your solution to be.
        I would probably just change the font in the resource file and use the WM_SETFONT call in WM_INITDIALOG after initializing the treeview component. Depending on the size, you may also need to call TVM_SETITEMHEIGHT. So this would be 3 lines of code, I guess.
