    help disabling smart quotes
    2 Posts 2 Posters 872 Views 1 Watching
    • Dave LangD Offline
      Dave Lang
      I’m not a notepad++ expert, but I’ve been using it for years. For some reason, today it started converting an apostrophe to a “curly” or “smart” apostrophe.
      Google will not tell me how to make it fuck off.
      Can someone here help? Frustrating.
      Thanks!
        Terry R @Dave Lang
        @Dave-Lang
        I’m not familiar with your problem but your issue did make me recall a previous post here.
        It might have occured as you just updated the version of Notepad++ from a very much older one, or possibly changed to a different font.
        Anyways, read that post and maybe you might find the answer.
