    Help with Regex/Find/Macro
    2 Posts 2 Posters 544 Views 1 Watching
    • João BorlothJ Offline
      João Borloth
      Good morning!
      Everyone, I couldn’t understand REGEX.
      I believe there’s a REGEX solution (Find or Filter) to solve my problem.
      I need Notepad++ to search line by line and find the lines that contain:
      1. A word with all letters in uppercase (example: LTDA)
      2. A word with all letters in lowercase (example: and)
      3. A word with mixed lowercase and uppercase letters (except capitalized words) (for example, find: hoUse, HOuse, HousE)
        but NOT find House.
      This would require 3 Regex and/or 3 macros.
      Example sentences:
      My HouSe is Beautiful => Find “HouSe” and “is”
      My House Is Beautiful => Ok, Don’t find anything
      MY House IS Beautiful => Find “MY”, “IS”
      Thank you
        Coises @João Borloth
        @João-Borloth said in Help with Regex/Find/Macro:
        Good morning!
          but NOT find House.
        Example sentences:
        Thank you
        Your example doesn’t quite match your statement. If, as per your statement, you want to find lines which contain one or more words that do not consist of a capital letter optionally followed by one or more lower case letters, then try:
        (?-is)^(?!\u\l*+([^\w\r\n]+\u\l*+)*+[^\w\r\n]*$).*+
        You can find them one by one, or click Find All to get a list.
        If, as per your example, you want to find words that do not consist of a capital letter optionally followed by one or more lower case letters, try:
        (?-is)\b(\u\l*+)?+\w++
        I tried to cover likely cases involving punctuation, but test. I’m not promising it’s perfect. (Come to think of it, I’m sure these will not handle words with apostrophes correctly.)
