    Add iNVERT cASE in the Right Click Menu
    2 Posts 2 Posters 581 Views 1 Watching
    • Michel MerlinM Offline
      Michel Merlin
      In the Right Click menu, after “UPPERCASE” and “lowercase” items, add a new one, “iNVERT cASE”, that would, as the 2 existing ones, point to the “Edit > Convert Case to” according item.
      Versailles, Fri 22 Aug 2025 17:37:50 +0200
        Alan Kilborn @Michel Merlin
        @Michel-Merlin
        You can customize the right-click context menu for your own use; consult the user manual (found via the ? menu in Notepad++) for details on how.
