    autoupdater and connection temp.sh
    Scheduled Pinned Locked Moved Security
    38 Posts 14 Posters 46.9k Views 5 Watching
    • Lycan ThropeL Offline
      Lycan Thrope @donho
      @donho, so if I’ve already auto-updated from 8.8.8 to 8.9.1, would it be necessary or advised to run it again, manually?
        donho @Lycan Thrope
        @Lycan-Thrope
        Once you have v8.9.1 installed, it won’t be necessary to update your Notepad++ manually - you can just let auto-updater do its job.
        Lycan ThropeL 1 Reply Last reply Reply Quote 1
        • Rickard StåhlR Offline
          Rickard Ståhl
          Hi
          If I understood the security issue correctly then it was the autoupdate functionallity that was compromised and that the advice is to download the latest version from the website and update.
          What is not clear to me is if a user clicks the “?” menu and then select “Update Notepad++”, if the update then is updated through the potentially compromised autoupdater function or if that is the same thing as downloading the MSI and installing it?
          I just want to be clear with the instructions to the users.
          • Marten van WezelM Offline
            Marten van Wezel
            Thank you for the work and clarity. Just one weird question, when I try to install the latest npp (8.9.1 x64), the “Auto-Updater” tickbox is greyed out and I can’t untick it. Strangely, after playing around with this window a bit it allowed me to untick it, but in context of this attack it’s not a great look?
            donhoD xomxX 2 Replies Last reply Reply Quote 0
              Marten van Wezel
              … and instant next post: after running the installer, because my previous install did have gup.exe, it should be noted gup was not removed, and npp in fact seems to happily use the old gup.exe now. I’ve verified it’s digital signature (all OK) but still… a bit messy?
              • M Offline
                Martin-1
                I created a new post not knowing this was already here. I do apologize.
                I am totally not in the know on any of these things so my questions are simple and I really can’t find an answer that tells me these things.
                As said, I understand very little about these sort of things. To start with:
                • I have had Notepad++ installed on my system for years and always have the auto update turned on. Currently Notepad++ is at version 8.9. I am not sure when it updated to that version though.
                • I run Windows 11 and there as well, the moment there is an update I get it installed.
                • I use Kaspersky Premium to protect my system.
                All I want to know are the following 3 things:
                1 - How do I know if my system was affected by this?
                2 - How do I clean the infection up if my system was affected by this?
                3 - What might they have stolen from my PC?
                They seem simple questions, but the answers I found were not really understandable for me.
                  PeterJones @Martin-1
                  @Martin-1 ,
                  Your questions were answered in reply to your post. Your questions were answered in the FAQ you were directed to. Your questions were answered earlier in this Topic. Please stop asking the same questions that have already been answered multiple times
                  M 1 Reply Last reply Reply Quote 0
                    donho @Marten van Wezel
                    @Rickard-Ståhl
                    “Update Notepad++” command uses auto-updater (GUP.exe).
                    At the bottom I provide the “simplied” clarification link for the concerned users.
                    @Marten-van-Wezel &
                    “how to disable the auto-updater” is included in the link of bottom.
                    @Martin-1
                    Short answer: Normal users are unlikely affected by this incident. Please see the link at the bottom.
                    FYI, the new IoCs (Indicators of Compromise) are published in the following link:
                    https://notepad-plus-plus.org/news/clarification-security-incident/
                      PeterJones @Rickard Ståhl
                      @Rickard-Ståhl said in autoupdater and connection temp.sh:
                      The ? > Update Notepad++ uses the builtin updater function.
                      In case it wasn’t clear: The function was not compromised. The website was, and for a tiny subset of users, when the website was hacked during the given date range, the website would return incorrect information. The website has been fixed already, so is no longer responding with incorrect information to anyone.
                      In the interim, the function has been improved to do better checks, so that if the hackers get better than the new website security again, they will not be able to use the same attack vector. That improved code would prevent downloading something based on incorrect information.
                      If you are running a version older than v8.8.8, the function hasn’t been improved: it’s not inherently “dangerous”, per se, since the website has been fixed; but out of an abundance of caution, the recommendation is to manually go to the official v8.9.1 download page https://notepad-plus-plus.org/downloads/v8.9.1/ which links to the download files stored on GitHub (or to go to the official GitHub releases page https://github.com/notepad-plus-plus/notepad-plus-plus/releases, download the installer yourself, and run the installer yourself, thus ensuring that you get the improved updater. After doing a manual download and installation of v8.9.1, the auto-updater will have the extra security features, and auto-update (or ? > Update Notepad++) will be more secure going forward.
                        PeterJones @Marten van Wezel
                        @Marten-van-Wezel said in autoupdater and connection temp.sh:
                        That’s the worst of both worlds. One of the points of manually downloading and installing v8.9.1 is that you don’t use the old gup for this single installation, but that the newer gup installed with v8.9.1 will have the added security features, so that auto-update will be more secure going forward.
                        But by what you did, you are now running with the newest notepad++.exe, which is fine and dandy, but there was nothing wrong or insecure with that; but you are also running with an old gup.exe, so the updater/installer doesn’t currently have the additional security features, which is a bad thing.
                        Either install the auto-updater when you manually install v8.9.1, so that you have the secure updater going foward, or manually delete the updater executables and dlls from C:\Program Files\Notepad++\updater (or the whole folder, really) if you don’t ever want auto-updater again. But do not use the mix of new-Notepad++-and-old-gup.exe which you currently have.
                        • Rai RR Offline
                          Rai R
                          Might be helpful to clarify in the news article that direct website links weren’t compromised (possible since they apparently had server access) and that having auto-updater enabled but refusing the update would not have led to your device being compromised since these were two subtle points that took a bit of digging here to figure out.
                            xomx @Marten van Wezel
                            You couldn’t untick it because of you also had the “Plugins Admin” selected at the same time (which needs the “Auto-Updater” component item for its functionality and thus “Auto-Updater” item cannot be unchecked until you also uncheck the “Plugins Admin”).
                            Yes, that was a problem before, should be fixed in v8.9+ installers by
                            https://github.com/notepad-plus-plus/notepad-plus-plus/commit/e89b0be86193c41f8170315ce4f6aa2386e96cf0
                            • J Offline
                              josephskit
                              Hi, I’m sorry to bother you wth such a stupid question, but it’s just for peace of mind, even if I know that the attack was highly selective.
                              Funnily the only time I have updated N++ during 2025 was on the 2nd of december. Was the update still provided by the compromised server on that day?
                                PeterJones @josephskit
                                @josephskit said in autoupdater and connection temp.sh:
                                Since the website remediation was “completed by the provider by December 2, 2025”, it presumably depends on what time of day it was when your update ran, and in what timezone you are in. Since you are on the borderline day, the best practice, as stated above, would be to manually download and install the v8.9.1 installer.
                                • M Offline
                                  Martin-1 @PeterJones
                                  @PeterJones That is what i meant. I don’t understand what is being said in those links or what is being said above. hence the repeat of my questions.
                                  I am not trying to make waves here, this is just a bit above my understanding.
                                  I always try to ask simple questions in the hope to get simple answers just so I can understand it all.
                                  • J Offline
                                    josephskit
                                    Just checked the date of the installer downloaded in the temp folder: UTC+0: 22:29.
                                    Also the statement from the provider says: “We discovered the suspicious events in our logs, which indicate that the server (where your application was hosted until the 1st of December, 2025) could have been compromised.”
                                    Anyway, I just installed the v8.9.1.
                                    I’ll try to not bother with it.
                                    Thank you!
                                      @Martin-1 said in autoupdater and connection temp.sh:
                                      Then ask for clarification, rather than ask the same thing over and over.
                                      Besides, the https://notepad-plus-plus.org/news/clarification-security-incident/ link that @donho most recently posted seems pretty clear to me:
                                      Who Was Targeted?
                                      This was a highly selective attack by a state-sponsored group targeting specific high-value organizations. Security researchers confirmed that the vast majority of Notepad++ users were never affected - attackers filtered victims based on strategic value, not random distribution.
                                      For most users: Simply updating to the latest version is sufficient.
                                      If you are a member of a a high-value organization, then you need to find someone on your IT team who does understand all the technical details. (If you are unsure whether your organization would be considered “high value”, then it wouldn’t be.) If you are not, then you are part of the “for most users” group. And those instructions seem quite clear to me: manually update to v8.9.1.
                                        Lycan Thrope @donho
                                        @donho ,
                                        Thanks for the verifcation, and sorry for the late reponse, I came down really sick that night for about a 5 day period after posting this, and am just getting back into the swing of things. Just wanted to make sure we didn’t need to be redundant about that process. Thanks again for the clarification.
