    Macro problem
    3 Posts 3 Posters 714 Views
      Hello, All,
      I need your help for a macro problem !
      On my portable v8.9 release of N++, I installed three plugins ComparePlus, Columns++ and NppUISpy
      I have two files, one in each N++ view .
      • In the main view, I have a list of regexes, in a txt file, in order to count the number of chars of any Unicode block. For instance :
      [\x{0000}-\x{007F}]      |     128  |  Basic Latin
      [\x{0080}-\x{00FF}]      |     128  |  Latin-1 Supplement
      [\x{0100}-\x{017F}]      |          |  Latin Extended-A
      [\x{0180}-\x{024F}]      |          |  Latin Extended-B
      [\x{0250}-\x{02AF}]      |          |  IPA Extensions
      [\x{02B0}-\x{02FF}]      |          |  Spacing Modifier Letters
      • In the secondary view, I have the Total_Chars.txt file, in N++ read-only mode, which contains all Unicode characters, minus the empty Unicode planes and few other zones
      So my goal is :
      • First, I select a regex, in the main view
      • Then, the macro :
        • Do the Copy action
        • Switch from main to secondary view
        • Open the Search dialog of the Columns++ plugin
        • Do the Paste action within the plugin dialog
      Here are the contents of this macro :
              <Macro name="Blocks" Ctrl="no" Alt="no" Shift="no" Key="0">
                  <Action type="0" message="2178" wParam="0" lParam="0" sParam=""/>
                  <Action type="2" message="0" wParam="44072" lParam="0" sParam=""/>
                  <Action type="2" message="0" wParam="22061" lParam="0" sParam=""/>
                  <Action type="0" message="2179" wParam="0" lParam="0" sParam=""/>
              </Macro>
      However, the Paste action does not occur and the search zone of the plugin is not updated with the clipboard contents :-((
      I also wanted, if possible, to get the total of chars, by hitting the Alt + T shortcut, within the Search dialog of the plugin
      Is there a mean to achieve such a goal ?
      TIA !
      P.S. :
      Of course, the paste action is not allowed within the Total_Chars.txt file which is a read-only file !
      But, when I added a new tab in the secondary view, it does paste the text in this new tab, and NOT within the Find what field of the Columns++ plugin !
      Thomas KnoefelT mpheathM 2 Replies Last reply Reply Quote 0
      • Thomas KnoefelT Offline
        Thomas Knoefel @guy038
        @guy038
        Yeah, macros can’t interact with plugin dialogs - that’s a Notepad++ limitation.
        MultiReplace might work as an alternative
        What it can do: Instead of counting one regex at a time via a macro loop, MultiReplace lets you run all your regexes against the file in a single “Find All” operation, No macro gymnastics needed.
        Here’s the quick rundown:
        1. Open MultiReplace, right-click list header → enable “Find Count”
        2. Add your regexes (with Regex checkbox enabled), or import via CSV:
        Selected,Find,Replace,WholeWord,MatchCase,UseVariables,Extended,Regex,Comments
        1,"[\x{0000}-\x{007F}]","",0,0,0,0,1,Basic Latin
        1,"[\x{0080}-\x{00FF}]","",0,0,0,0,1,Latin-1 Supplement
        1. Open Total_Chars.txt, click “Find All”
        The Find Count column shows all matches at once. Works with read-only files.
        The catch: it’s batch, not interactive. And the counts aren’t in CSV export yet - you’d copy them manually. (That feature is on my list right now.)
        • mpheathM Offline
          mpheath @guy038
          @guy038
          https://www.scintilla.org/ScintillaDoc.html#SCI_COPY
          copying data to the clipboard
          Is document to the clipboard.
          https://www.scintilla.org/ScintillaDoc.html#SCI_PASTE
          pasting from the clipboard into the document
          Is clipboard to the document.
          Both functions relate to the document in the editor. The copy function will be good for the task though paste will not work with the search window.
          Instead of SCI_PASTE, could use the Run command to run an executable to insert the clipboard text into the search window.
          AutoIt3 script automate_columns++_search.au3 :
          ; Wait up to 3 seconds for the window.
          $hSearch = WinWait('Search in indicated region', '', 3)
          If $hSearch Then
              $sClip = ClipGet()  ; get clipboard text
              ControlSetText($hSearch, '', 'Edit1', $sClip)  ; set combo edit
              ControlClick($hSearch, '', 'Button7')  ; click regex button
              ControlClick($hSearch, '', 'Button9')  ; click count button
              $sCount = ControlGetText($hSearch, '', 'Static3')  ; read label
              ClipPut($sCount)  ; set clipboard text
          EndIf
          Adjust the title if the window text is localized.
          Compile to executable and then add to Run as a command. Get the command id with NppUISpy and insert into the shortcuts.xml file.
