    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Find and Replace blank spaces (char32) with Regular Expression seems to Lock up NP++
    Help wanted · · · – – – · · ·
    • Stephen Frick
      Stephen Frick last edited by
      I have a large text document that I’m removing multiple blanks (char32) and replacing them with a single space - I’m using the Replace - Find what: ( )* and Replace with is a single space. I’m using Regular expression and the . matches newline is checked. When I run this on my text, no matter the size it locks up and shows (Not Responding) on the window. It seems like an infinite loop. I don’t want to use \s* because I want various control characters, all I want is char32 to be found and replaced.
      Am I doing something wrong or is this a bug?
      Thanks for your help,
      • guy038
        guy038 last edited by
        Hello Stephen,
        In my opinion, Stephen, you didn’t understand, exactly, the use of the . matches new line option. By default, with the regex engine of N++, the special character dot . matches ANY character DIFFERENT from the 3 characters, below :
        • The New Line character, displayed as LF, = \n ( \x0a )
        • The Carriage Return character, displayed as CR, = \r ( \x0d )
        • The Form Feed character, displayed as FF, = \f ( \x0c )
        So, when you CHECK the option . matches new line, then the dot matches, absolutely, ALL the characters of a file. This option allows the user to build multi-lines searches.
        For instance, the regex 123.*789 with the .matches new line set, tries to match the longest string, from a first occurrence of 123 to the last occurrence of 789, in the current file, even though the string 789 is located some lines after the string 123 :-)
        So, as you can see, this option has no relation, at all, with the search of spaces, anyway !
        To achieve your S/R ( Multiple spaces -> ONE space ), that’s quite easy :
        SEARCH = +, with TWO spaces before the + sign and REPLACE = ONE space
        The search regex matches a single space, followed by a non null sequence of spaces. An other syntax would be :
        SEARCH = \x20\x20+ and REPLACE = \x20 ( decimal number 32 = hexadecimal number 20 )
        You could also use a look-behind to detect the first space :
        SEARCH = (?<= ) +, with a space after the = sign and before the + sign and REPLACE = Nothing.
        However, due to a bug of the regex engine, you must click on the Replace All button, ONLY. Don’t use the Replace button, for the S/R, just above.
        Best Regards
        P.S. :
        You’ll find good documentation, about the new Boost C++ Regex library, v1.55.0 ( similar to the PERL Regular Common Expressions, v1.48.0 ), used by Notepad++, since its 6.0 version, at the TWO addresses below :
        http://www.boost.org/doc/libs/1_48_0/libs/regex/doc/html/boost_regex/syntax/perl_syntax.html
        http://www.boost.org/doc/libs/1_48_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
        • The FIRST link explains the syntax, of regular expressions, in the SEARCH part
        • The SECOND link explains the syntax, of regular expressions, in the REPLACEMENT part
