    CallTips - How to Add Keywords with Spaces
    6 Posts 2 Posters 5.7k Views 1 Watching
    • Sathish KumarS Offline
      Sathish Kumar
      I have created a Auto completion list with Keywords having Spaces like ‘Alias1 2 3’ but Np++ is showing Alias1, 2,3 as the Auto complete list.
      Could you please help me on how to make NP++ to display Keyword with spaces in Autocomplete list.
      Thanks and Regards,
      Sathish.
      • dailD Offline
        dail
        Currently that does not seem possible. Internally the keywords are joined together into a list by using spaces, so if a keyword happens to have a space in it, then it sees it as two keywords.
        In theory with a few code modifications it would be possible though.
          Sathish Kumar
          How can I make the code modification to show words with spaces?
          • dailD Offline
            dail
            Internally Notepad++ would have to use a different character (one that does not show up in the keywords) to join the keywords. Most likely this would be a configurable option in the xml file. Then that character would be specified to Scintilla when calling SCI_AUTOCSETSEPARATOR.
              Sathish Kumar
              I have added following line in xml but no luck with spaces.
              <Environment ignoreCase=“yes” startFunc=“(” stopFunc=“)” paramSeparator=“,” terminal=“;” additionalWordChar=“\s”/>.
              How can I configure the space to accept in XML.
              • dailD Offline
                dail
                I was meaning C++ code modifications.
