    Plugin built with VS 2013 Express vs. Plugin built with VS 2013 Community
    24 Posts 2 Posters 28.5k Views 2 Watching
      Claudia Frank
      Hello Yaron,
      The problem is generated by a compiler bug. It tries to optimize a little bit too much. ;-)
      Either disable optimization, by right clicking on compare in project explorer,
      properties -> C/C++ -> all options -> Optimization and change its value
      or the preferred way
      update your visual studio 2013 to latest version. ;-)
      • YaronY Offline
        Yaron
        Hello Claudia,
        You never cease to amaze me.
        I take my hat off. Oracle Claudia!
        Thank you so much. I’m truly grateful.
        Could you please enlighten me and explain briefly how you got it?
        I hope it’s not a trade secret. :)
        Best regards.
          Claudia Frank
          Hello Yaron,
          no, it isn’t a trade secret ;-) - but it wasn’t really a clever job, it was just an eliminating process and LUCK.
          I only tell you the steps which lead to the finding not the many wasted miserable steps I’ve done before. ;-)
          After I didn’t find any obvious issues which could explain reported behavior I thought about the differences of your
          and mine environment. After that I setup an windows 7 32 bit with visual studio 2013. Downloaded source and compiled it.
          Tested it and it worked. Even more confused as I expected it to fail. Thought about it again and started comparing yours and mine.
          Same W7, same VS2013, same source -> different results.
          Same W7 (?) -> didn’t install all updates -> didn’t use Hebrew = keep in mind
          VS2013 -> same
          source-> same, you did even test it with different npp version as I read.
          So it must be W7 -> why??? Did a search on the internet about reporting problem with VS2013 and non-english language.
          Results, but nothing pointing to such an issue.
          Then I did a search about problems with visual studio and having different language. And while scanning the result
          I saw one who had an issue installing an update - that’s where I started thinking about different version.
          I had VS2013 update 4 already so I gave it a chance and -> compiled the source and tested it -> problem was the same.
          You see, no rocket science.
          • YaronY Offline
            Yaron
            Hello Claudia,
            Thank you for the explanation. You know, men can get curious too. :)
            And now I just can’t help it.
            After explaining the process of reasoning leading to her famous deductions, Shirley Holmes’ insights seemed to lose some of their former glamour.
            But then on a second thought the shine became even brighter.
            Well, I assumed you had performed some searches and tests.
            Now that I know the scale of those actions, my gratitude grows and deepens.
            And finally, rocket science would be no “rocket science” for you. :)
            Best regards.
