    HexEditor.dll not loading for some users
    please helpplugin
    8 Posts 2 Posters 9.5k Views
    • baedeanB
      baedean
      No problem w/ NP++ on the account I used to install NP++, but on another account NP++ spins when launching & eventually reports that HexEditor.dll failed to load.
      I had this w/ an older version, so tried the latest (7.3) & used the latest plug-in mgr to install everything. I only had admin/elevated right for the installs.
      dll permissions look fine. Any other ideas?
      Thanks,
      • Claudia FrankC
        Claudia Frank @baedean
        @baedean
        provide more information what the different about your account and the others is.
        Are those accounts working on the same computer? Terminal Services?
        Debug-info?
        • baedeanB
          baedean
          This biggest different is the problem user is a local account (vs. corporate domain). I get the same behavior running directly and remotely. Not sure what else to look for.
          Thanks.
          • Claudia FrankC
            @baedean
            please provide the Debug-info
            menu ?->Debug Info
            • baedeanB
              baedean
              I see it now (used to an older version w/o this option).
              The information is the same for both users (w/o HexEditor):
              Notepad++ v7.3 (32-bit)
              Build time : Jan 1 2017 - 20:04:42
              OS : Windows 7
              Plugins : mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll PluginManager.dll SpellChecker.dll
              When I move HexEditor.dll back to Notepad++\plugins (from disabled), only difference:
              Plugins : HexEditor.dll mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll PluginManager.dll SpellChecker.dll
              Thanks again.
              • Claudia FrankC
                @baedean
                the npp version needs to be
                always, as, afaik, there is no 64bit version of the hexeditor plugin and as you are using
                it is assumed that the plugin is available under %APPDATA%\notepad++\plugins.
                If this is the case, then I would try to compare your hexeditor dll with one which isn’t working.
                • baedeanB
                  baedean
                  HexEditor.dll is in Program Files/… (not APPDATA).
                  After reading your last post, I did try putting the dll in %APPDATA%\notepad++\plugins, but it doesn’t seem to get loaded from there.
                  • Claudia FrankC
                    @baedean
                    then it means that you installed npp with the option to use %APPDATA%\notepad++
                    as the configuration directory but did not check the box to allow plugins to be loaded
                    from there as well. Confusing - but you might have reasons to do so.
                    And your computer/account is having the same configuration?
                    I would try to use procmon to see where npp tries to find the plugins.
