    XML tools 2.4.9 32 bit - problem with AppData Folder
    3 Posts 3 Posters 5.1k Views 2 Watching
    • neo7BFN Offline
      neo7BF
      With this configuration works fine:
      Main notepad++ Folder:
      • libcurl.dll <------
      • allowAppDataPlugins.xml
      %AppData%\Notepad++ Folder:
      • libiconv-2.dll
      • libwinpthread-1.dll
      • libxml2-2.dll
      • libxslt-1.dll
      • zlib1.dll
      %AppData%\Notepad++\plugins Folder:
      • XMLTools.dll
      With this hand I get the error from Notepad++: “Impossible to start program because libcurl.dll was not found in the computer.”
      • libiconv-2.dll
      • libxml2-2.dll
      • libxslt-1.dll
      • zlib1.dll
      • XMLTools.dll
      Why libcurl.dll can not be located in %AppData%\Notepad++ folder along with the other files ?
        Claudia Frank @neo7BF
        @neo7BF
        I assume this is a question you have to ask the developer of xml tools.
        • chcgC Offline
          chcg
          See https://notepad-plus-plus.org/community/topic/12556/xml-tools-2-4-9-x64-released-for-tests/10, seems still unchanged
