    Help with recoveries
    2 Posts 2 Posters 1.5k Views 2 Watching
    • Luis Piña IIIL Offline
      Luis Piña III
      I need to know if there is a way to recover what was in opened unsaved tabs.
        Claudia Frank @Luis Piña III
        @Luis-Piña-III
        depending on how you installed notepad++ you do have either a
        backup directory under INSTALL_DIRECTORY\notepad++
        or under %APPDATA%\notepad++.
        Check if you find the files there, if you can’t find it they are most probably gone.
