    Tabs Disappear Problem
    2 Posts 2 Posters 1.6k Views 2 Watching
    • Dr MehtiD Offline
      Dr Mehti
      Hi there , I have problem with My Tabs , i used notepad++ for days and i opened a lot of new tabs , but today when i run notepad++ i see that all the tabs are disappeared even my theme config back to default !!!
      ** so the main question is : **
      why tabs disappeared after days ?
      another question is :
      When i open a new tab and for example i type in that this string “this is a test”
      where goes the file that keeps tab content ( i mean the string ) ?
      Image Before
      Image After
        Claudia Frank @Dr Mehti
        @Dr-Mehti
        could it be that you run some software like ccleaner?
