    Help converting Notepad++ format to Pythonscript
    16 Posts 4 Posters 4.8k Views 3 Watching
    • Andrew ClarkA Offline
      Andrew Clark
      I am trying to create a Pythonscript program to convert old CNC programs to a newer format. I am using the editor.rereplace() format to do this and have most of my functions working this way. I am having trouble with one specific format. In Notepad++ I would use Find/Replace with the following conditions to achieve what I want, line by line.
      Find: ((.?))|(a-z([-#]?\d(.\d)?))\s
      Replace: $1$2
      This removes any spaces in the program that are NOT inside of parenthesis and that would otherwise make every other regex more difficult. I cannot seem to get that function working in Pythonscript. I have tried adding enumerable escapes ( \ ) and nothing seems to be working for me. Here are a few examples of before and after code.
      BEFORE
      O1234
      (EXAMPLE PROGRAM)
      (THIS IS A CNC COMMENT)
      (I WANT THESE LINES TO RETAIN SPACES)
      G28 G91 Z0
      T1 M6 (EXAMPLE TOOL)
      M3 S10000
      G90 G0 G95 G54 X1.0 Y2.0
      G43 Z0.25 H1 D1 M8
      G1 Z-1.0 F0.006
      X-1.0 Y-2.0
      Y2.0
      X1.0
      G0 Z1.0 M5
      G28 G91 Z0 M9
      M01 (CHECK PART)
      AFTER
      O1234
      (EXAMPLE PROGRAM)
      G28G91Z0
      T1M6(EXAMPLE TOOL)
      M3S10000
      G90G0G95G54X1.0Y2.0
      G43Z0.25H1D1M8
      G1Z-1.0F0.006
      X-1.0Y-2.0
      Y2.0
      X1.0
      G0Z1.0M5
      G28G91Z0M9
      M01(CHECK PART)
      Notice that the spaces OUTSIDE of the parenthesis have been removed. Can anyone help me with the proper formatting to make this work? Thanks!
      Claudia FrankC S 2 Replies Last reply Reply Quote 0
        Claudia Frank @Andrew Clark
        @Andrew-Clark
        from the given example this should do the job
        lines = editor.getCharacterPointer().splitlines()
        new_lines = []
        for line in lines:
            if '(' in line:
                pos_round_bracket = line.find('(')
                _line = line[:pos_round_bracket].replace(' ','')
                _line += line[pos_round_bracket:]
                new_lines.append(_line)
            else:
                new_lines.append(line.replace(' ',''))
        editor.beginUndoAction()
        editor.setText('\r\n'.join(new_lines))
        editor.endUndoAction()
          Scott Sumner @Andrew Clark
          @Andrew-Clark
          Since you are already in Pythonscript, why don’t you forget regex and go with “brute force”, something like this, or something similar? (admittedly this does not do the “ultimate” in error-checking, but it is just supposed to be an idea to get you on an alternate track of thinking–if that’s where you want to go…):
          new_text = ''
          inside_parens = False
          for in_ch in editor.getText():
              if not inside_parens and in_ch == ' ':
                  continue
              elif in_ch == '(':
                  inside_parens = True
              elif in_ch == ')':
              new_text += in_ch
          editor.setText(new_text)
            Andrew Clark
            Well, that works fantastic! I actually set out to use a more programmatical approach to this, but found that I could do almost all of the things I wanted to with simple regex. It wasn’t until I hit the need described above that I got stuck. The regex for it worked, but I couldn’t get the code to work in Pythonscript.
            It will take some digging to follow what you did with that code, but it should help me with more advanced alterations in the future…when I get there. Thanks!
              @Andrew-Clark
              Not sure if you are directing that response to @Claudia-Frank or to me…but I’ll say this about the regex approach: I never understood how your regex worked live with Notepad++ – maybe the markdown syntax on this site was “stealing” some parts of it.
              If I try it as I see it above I get this as the AFTER text, which is clearly not right:
              OO11223344
              ((EEXXAAMMPPLLEE  PPRROOGGRRAAMM))
              ((TTHHIISS  IISS  AA  CCNNCC  CCOOMMMMEENNTT))
              ((II  WWAANNTT  TTHHEESSEE  LLIINNEESS  TTOO  RREETTAAIINN  SSPPAACCEESS))
              GG2288  GG9911  ZZ00
              TT11  MM66  ((EEXXAAMMPPLLEE  TTOOOOLL))
              MM33  SS1100000000
              GG9900  GG00  GG9955  GG5544  XX11..00  YY22..00
              GG4433  ZZ00..2255  HH11  DD11  MM88
              GG11  ZZ--11..00  FF00..000066
              XX--11..00  YY--22..00
              YY22..00
              XX11..00
              GG00  ZZ11..00  MM55
              GG2288  GG9911  ZZ00  MM99
              MM0011  ((CCHHEECCKK  PPAARRTT))
              What gives? Shouldn’t I see some \( and \) sequences in the regex?
                Andrew Clark
                @Scott-Sumner said:
                @Andrew-Clark
                OO11223344
                GG2288  GG9911  ZZ00
                MM33  SS1100000000
                YY22..00
                XX11..00
                GG00  ZZ11..00  MM55
                My response was directed at Claudia. And you’re right, the code I posted above does not result in the proper result in Notepad++. Something must have been lost. I could go back and find it, but at this point my question has been answered so I am going to call this topic closed. Thank you all for the responses!
                  @Andrew-Clark
                  sorry, didn’t understand that you want a python script solution with regular expression replacement.
                  regex = r'(\(.*?\))|(\w+)\s'
                  editor.rereplace(regex, lambda m: '{}{}'.format(*m.groups()))
                    Scott Sumner
                    I am most-curious about why the OP (@Andrew-Clark) could get his regex replacement working in interactive N++ and not with Pythonscript, but perhaps that is a question that isn’t going to get answered…my guess would be not using raw string notation (the leading r in r'regex') in the PS…
                      Claudia Frank
                      or maybe it was about how to get the match groups returned as replacement … ??
                        Hello @andrew-clark, @scott-sumner, @claudia-frank and All,
                        I was away this weekend, to hike in the Cevennes mountains and my feet still remember theses rides ! As you can imagine, just sitting, comfortably, in front of your laptop and discussing Notepad++ matters is a real treat ;-))
                        So, Andrew, as for me, I would use, with native N++, the regex S/R, below :
                        SEARCH (?-s)(\(.+?\))|\x20
                        REPLACE ?1\1
                        Notes :
                        • As usual , the (?-s) modifier means that any regex dot character ( . ) will match a single standard char., only.
                        • Then, this regex would match :
                          • First, any shortest range of chars, between parentheses, stores it as group1 and rewrites this group as it is. ( Note that the ( and ) characters have to be escaped, with a \ symbol, to be considered as literals ! )
                          • Secondly, any space character, just ignored in replacement.
                        Claudia FrankC 1 Reply Last reply Reply Quote 2
                          Claudia Frank @guy038
                          @guy038
                          Hi Guy, nice shortening but one question - it seems that ?1 is, for the posted example data, not needed in the replacement - what is the idea behind it?
                          Thank you and cheers
                            Claudia Frank
                            Just in case someone wants to add this into a python script it would now look like this
                            regex = r'(?-s)(\(.+?\))|\x20'
                            editor.rereplace(regex, lambda m: '{}'.format(m.groups()[0]))
                              Scott Sumner @Claudia Frank
                              I don’t know…the Pythonscript docs for editor.rereplace() seem to have an adequate example of this…but considering it now maybe it could be made better?
                                Claudia Frank @Scott Sumner
                                @Scott-Sumner
                                there is always room to improve something - so, yeah - go for it. :-D
                                  Hi, @andrew-clark, @scott-sumner, @claudia-frank and All
                                  Sorry, for my late answer as I was elaborating a regex, for the tricky case, below :
                                  https://notepad-plus-plus.org/community/topic/16053/how-to-ascend-numbers/3
                                  Ah, how silly am I ! Of course, when the regex finds a space character ( the second alternative ), the group1 is not defined. Thus, in replacement, it simply rewrites…nothing, as group1 represents a zero-length string ;-))
                                  Clever deduction, Claudia. So a possible regex is :
                                  SEARCH (?s)(\(.+?\))|\x20
                                  REPLACE \1
                                  Note : I also changed the (?-s) modifier into (?s), which allows possible multi-lines ranges of text, between parentheses !
                                    Ah :-(( I should have tested my idea of changing (?-s) into (?s), before posting. Actually, in case of multi-lines range of characters, between parentheses, the suitable regex S/R is , rather :
                                    SEARCH (\([^()]+?\))|\x20
                                    REPLACE \1
                                    Hope it’s the right one, this time :-D
