    XMLTools not compatible with Notepad++ 7.5.8 64-bit
    10 Posts 10 Posters 35.1k Views 2 Watching
    • Andrew FlintA Offline
      Andrew Flint
      Hi
      I’ve installed Notepad++ and Plugin Manager both 64-bit. Then used Plugin Manager to install XML Tools 2.4.9.2. However, when Notepad++ starts I get “XMLTools.dll is not compatible with the current version of Notepad++.” Any idea how to fix this?
      Thanks
      Andy Flint
      Notepad++ v7.5.8 (64-bit)
      Build time : Jul 23 2018 - 02:06:36
      OS : Windows 10 (64-bit)
      Plugins : PluginManager.dll DSpellCheck.dll mimeTools.dll NppConverter.dll
      • chcgC Offline
        chcg
        I don’t see this problem on win10 with the installationof XML Tools 2.4.9.2 from PluginManager. Maybe you want to create an issue at https://github.com/morbac/xmltools/issues therefore and releases are available at https://sourceforge.net/projects/npp-plugins/files/XML Tools/Xml Tools 2.4.9 Unicode/
        • Rajeev DhanawadeR Offline
          Rajeev Dhanawade
          You might have missed step number 4 in the Install text file. Once I copied those 6 dlls to the NPP root file, it was all good.
          Hope this helps.
          Chris WernerC 1 Reply Last reply Reply Quote 1
          • Rajat KuchhalR Offline
            Rajat Kuchhal
            I faced same issue as Andrew, What Rajeev suggested worked for me.
            • Gerard HaydenG Offline
              Gerard Hayden
              I found that this did not help but I was able to add the x86 version.
              • arni992A Offline
                arni992
                I have tried several options, and it worked when I made folder “XMLTools” in "plugins"with XMLTools.dll in it.
                xeniroxX 1 Reply Last reply Reply Quote 1
                • xeniroxX Offline
                  xenirox @arni992
                  @arni992 Thank you, your solution worked for me!
                  • R Offline
                    rinku singh
                    https://github.com/pnedev/nppgtags/issues/26#issuecomment-550320502
                    • Chris WernerC Offline
                      Chris Werner @Rajeev Dhanawade
                      @Rajeev-Dhanawade said in XMLTools not compatible with Notepad++ 7.5.8 64-bit:
                      Hope this helps.
                      I hate to necro a post… but dammit… this was the answer. +100 internet points.
                      • Praveen KP Offline
                        Praveen K
                        XMLTool, Xml Tools 2.4.9.2 x64 Unicode.zip.
                        Once you unzip the Xml Tools 2.4.9.2 x64 Unicode.zip then you will see the folder structure below.
                        C:\Program Files\Notepad++\plugins\2.4.9.2 x64 Unicode
                        Open the dependencies folder. You will find all the dlls.
                        Copy all the dll to the folder consisting of Notepad++.exe, except XMLTools.dll in Notepad++ plugins folder.
