    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Notepad++ Not Responding
    Help wanted · · · – – – · · ·
    • tankcr
      tankcr last edited by
      As of today every time I attempt to launch NPP it just goes into a not responding state. I tried an uninstall/reinstall and this did not resolved the problem. Any help is hugely appreciated!!!
      Win10/X64 version
      • gus0074
        gus0074 last edited by
        Hi, same problem here. The new version of Notepad++ (7.5.9) hangs many times, some times, when opening the program or opening a text file with it. This happens to this new version only, older version always worked perfectly. I’m using Windows 10.
        • chcg
          chcg last edited by
          See https://notepad-plus-plus.org/community/topic/15739/faq-desk-request-for-help-without-sufficient-information-to-help-you
          Don’t observe this with Win10, 64bit, N++ 7.5.9
          • chcg
            chcg last edited by
            There is a known performance issue with 7.5.9, see https://notepad-plus-plus.org/community/topic/16468/notepad-7-5-9-release/21
            Is this the behaviour you observe?
