    UDL: Suffix Mode
    54 Posts 8 Posters 28.9k Views 1 Watching
      Ekopalypse @Alexander Seidel
      @Alexander-Seidel
      I will follow up on this later today from at home as I’m finished with work today. YEAH :-D
        @Alexander-Seidel
        Hi Alexander, concerning number 2 I would add
        self.excluded_styles = [1, 2]  # SCE_USER_STYLE_COMMENT=1  SCE_USER_STYLE_COMMENTLINE=2
        to the init function like
                def __init__(self):
                    editor.callbackSync(self.on_updateui, [SCINTILLANOTIFICATION.UPDATEUI])
                    notepad.callback(self.on_langchanged, [NOTIFICATION.LANGCHANGED])
                    notepad.callback(self.on_bufferactivated, [NOTIFICATION.BUFFERACTIVATED])
                    self.__is_lexer_doc = False
                    self.lexer_name = None
                    self.npp_hwnd = user32.FindWindowW(u'Notepad++', None)
                    self.configure()
        and modify the if clause line in paint_it function to
        if (pos >= 0) and (editor.getStyleAt(pos) not in self.excluded_styles):
        that would skip painting if the matched position is in a comment line or block
        Regarding the first point, no, unfortunately scintilla doesn’t allow to modify
        the font attributes via an indicator other than the foreground color.
        But I’m confused why it is italic at all, in UDL you must have it set explicitly, didn’t you?
        • Alexander SeidelA Offline
          Alexander Seidel
          Thanks for the quick work, Eko!
          Sadly, the code doesn’t work :(
          Now, I checked the conditional function, and noticed that getStyleAt returns 0 if the pos is out of bounds, but weirdly, when I use this line:
          if (pos >= 0) and (editor.getStyleAt(pos) == 0):
          the code works and does so just as I intended. Comment lines are not changed, but normal lines are.
          I really don’t get why it does, because I expected it to only return 0 in case of an error, and not for normal lines in the text, but apparently that’s how it works.
          Concerning the italic: Yes, I set a lot of variably type names like int and double to italic, but the language I’m programming in also has int(“4”) and string(4) as functions at the same time.
          EkopalypseE 2 Replies Last reply Reply Quote 0
            @Alexander-Seidel
            sorry, Hochmut kommt vor dem Fall, I didn’t test it otherwise I would have
            seen that paint_it is a staticmethod and as such it has no access to self object.
            Remove the @staticmethod decorator and add self to be the first parameter
            to paint_it like this
                    def paint_it(self, color, pos, length):
                            editor.setIndicatorCurrent(0)
                            editor.setIndicatorValue(color)
                            editor.indicatorFillRange(pos, length)
            If you open the console window while having the old version running,
            you should see that it throws an error - so it didn’t do anything at all.
            getStyleAt returns the style id and you compare with style 0, so it works as long as the part to be colored is currently colored with the style 0.
            Which means, your code is good as well if you are only interested
            in modifying parts of code which are used by style 0.
              @Alexander-Seidel
              regarding the italic issue, what about using a delimiter with
              open int( and closing ) and setting it color to the default color?
                Alexander Seidel
                @Ekopalypse said in UDL: Suffix Mode:
                If
                I just used this line now:
                if pos >= 0 and (editor.getStyleAt(pos) not in [1, 2]):
                and nice tip for the italics! That worked perfectly. I first tried to just make a keyword int(, but that didn’t work.
                  @Alexander-Seidel
                  or like this yes :-) Many roads to Rome I guess :-D
                  • bruhB Offline
                    bruh
                    self.regexes[(0, self.rgb(79, 175, 239) | SC_INDICVALUEBIT)] = (r’fn[A-Za-z0-9_]+?$|([A-Za-z0-9_]+?$)', 1)
                    Will adding ^\w+.(gif|png|jpg|jpeg)$ instead of r’fn[A-Za-z0-9_]+?$|([A-Za-z0-9_]+?$)’ make it work on .gif .png .jpg and .jpeg suffixes?
                      Ekopalypse @bruh
                      @bruh said in UDL: Suffix Mode:
                      you mean for highlighting?
                      bruhB 3 Replies Last reply Reply Quote 0
                      • bruhB Offline
                        bruh @Ekopalypse
                        @Ekopalypse Yeah highlighting the entire word thst contains .gif or the others
                        • bruhB Offline
                          bruh
                          • bruhB Offline
                            bruh @Ekopalypse
                            • bruhB Offline
                              bruh @Ekopalypse
                              @Ekopalypse Nvm yet again i just added everything ie [0-9a-zA-Z_/\-.|+-#$!"%&()=?*@'~\ˇ^\˘\°;:,{}\˛`\˙\´\¨\¸\ß\Ł\ł\¤\×\÷\č\ć\ž\đ\p\š\€\§] and it works xD sry for the spam
                                Ekopalypse @bruh
                                @bruh
                                … and it works
                                Great, if anything is unclear or I can do, let me know.
