    Plugins > Plugins Admin... missing
    4 Posts 2 Posters 85.5k Views 1 Watching
    • papryka1P Offline
      papryka1
      I want to add NppFTP plugin but there is no “Plugins Admin…” http://prntscr.com/n6ba73
      I tried launching NotePad++ with admin and searched for info in this forum but can’t find anything.
      How can I solve it ?
      • Meta ChuhM Offline
        Meta Chuh moderator @papryka1
        welcome to the notepad++ community, @papryka1
        we do not have your current debug information, so here is a general guide:
        one thing that can cause what you see is, if the plugin list is missing.
        please go to plugins > open plugins folder... and look for a folder called Config. this has to contain a file called nppPluginList.dll, which contains the plugin list.
        (in your case you will have to browse manually to your notepad++ program and plugins folder, e.g.:
        C:\Program Files\Notepad++\plugins\Config or C:\Program Files (x86)\Notepad++\plugins\Config and check if the file called nppPluginList.dll is missing)
        how to re-install plugins admin:
        • 32 bit: if nppPluginList.dll or the whole Config folder is missing, please re-install notepad++ 7.6.5. 32 bit over your existing notepad++ 32 bit, by using the installer from here:
          https://notepad-plus-plus.org/repository/7.x/7.6.5/npp.7.6.5.Installer.exe
        • 64 bit: if nppPluginList.dll or the whole Config folder is missing, please re-install notepad++ 7.6.5. 64 bit over your existing notepad++ 64 bit, by using the installer from here:
          https://notepad-plus-plus.org/repository/7.x/7.6.5/npp.7.6.5.Installer.x64.exe
        (uninstall of the existing notepad++ is not necessary)
        important: when you re-install notepad++ over your existing notepad++, make sure that the installer options plugins and plugins admin are enabled.
        note: on some occasions you will have to re-install twice, first time de-selecting the options plugins and plugins admin, and then re-installing another time activating both options plugins and plugins admin.
        • papryka1P Offline
          papryka1
          Thanks for the help! Got it all working.
            @papryka1
            splendid, thanks for reporting back, you are welcome.
            • epikgitE epikgit referenced this topic on
