Suggestion if it's not possible.
Hi. So I don’t use N++ for code much just writing, I like the layout. Anyway in Leafpad for Linux, when something is typed in the search bar, you can hit Ctrl + G and it shows the next location of the word in search without having to hit enter or click on the box to highlight it to then hit enter to find the next one, wondering if Notepad ++ has anything like that or you can make a keybind if anyone knows? PS not sure were requests are, but the search function I believe has also been changed to remove the ability for a search to restart at the top once it’s at the bottom of the doc like Microsoft’s notepad which should be change back. But anyway thanks.
Not sure this makes much sense. It seems like you are trading off pressing one key (Enter) for pressing a different one (ctrl+g). One key in each case; what’s the difference?
Tick the Wrap around box.
Well it’s a lot faster, since what I’m doing is taking sentences that have tags above them, like “intro”, into a folder for the intro whatever project I’m introducing, and since switching over to N++ it’s had a big affect how fast I complete the task, because I work with docs that are like 80,000 words long, and if I was to ,
highlight, ctrl, x, ctrl, v, then ctrl g, it’d speed up my time immensely.
I’m not really following enough to offer suggestions. Maybe someone else?
i can’t offer
ctrl+g, but if you do such searches often, you can give the dockedincremental searcha shot.
you can summon it withsearch > incremental searchorctrl+alt+i.keyboard controls:
enter= next,shift+enter= previous.
and if you activatehighlight all, you have a nice extra highlighting coloured in blue, which differs from the usual green mouse selection highlighting.incremental search screenshot (the little docked search bar at the bottom):
this option’s default setting never changed, so it might be disabled by accident on your system.
please activatewrap aroundat the search/replace panel, as seen at the next screenshot:
many thanks and best regards.
