    Tab key position is not same notepadd++ and notepad
    2 Posts 2 Posters 804 Views 1 Watching
    • Wisely ShihW Offline
      Wisely Shih
      for the normal, I use tab key to arrangement text location.
      but I saw the text location is not same Windows notepad location.
      my text file format is windows format, and my NP++ version is v7.5~7.7.1 64bit and 32bit. (maybe early version is same issue.)
      how to let position are same the location between NP++ and Windows notepad, when I use tab key to arrangement text location.
        Ekopalypse @Wisely Shih
        @Wisely-Shih
        not 100% sure I understand what you are trying to achieve but …
        could it be that you are referring to the fact the MS notepad uses a tab width of 8
        whereas npp uses 4?
        If so, goto settings->preferences->language and set the tab size accordingly.
