    Serch for "numbers"?
    11 Posts 3 Posters 1.6k Views
    • Tino Salskov LarsenT Offline
      Tino Salskov Larsen
      I have a long txt file with filnames.
      I need to search for files which names are fx.
      summer1.2019.21.11
      summer2.2019.21.11
      summer3.2019.21.11
      What do I need to use instead of ‘?’ ,so I can search for summer?.2019 and get every filename, when they have a different number somewhere in the name…
        Alan Kilborn @Tino Salskov Larsen
        @Tino-Salskov-Larsen
        How about summer\d\.2019 ?
        Tino Salskov LarsenT 1 Reply Last reply Reply Quote 1
          Tino Salskov Larsen @Alan Kilborn
          @Alan-Kilborn does not work… :-(
            Ekopalypse @Tino Salskov Larsen
            did you check regular expression in find dialog?
            Tino Salskov LarsenT 1 Reply Last reply Reply Quote 0
              Tino Salskov Larsen @Ekopalypse
              @Ekopalypse yes…
                Ekopalypse
                then either your real data must look different to the one you posted
                or your cursor is at a position which doesn’t have such filenames afterwards.
                Note, in regex there is a hugh difference between summer1… and summer11…
                  @Ekopalypse Sorry, it work with summer etc… but my files name are HH2009D.2019 or. HH2001D.2019 - so I need the “wildcard” \d\ before the letter d… can that be an issue??
                    Ekopalypse
                    Yes, of course, Alans regex can be described as
                    search for summer
                    followed by one digit (\d)
                    followed by a literal dot (\.)
                    followed by 2019
                    which doesn’t find
                    HH
                    followed by digits (all of them or only the last one?)
                    followed by D
                    followed by 2019
                    Tino Salskov LarsenT 1 Reply Last reply Reply Quote 2
                      @Ekopalypse I can see if I use HH200\DD\.2019 it works… :-) Thank you…
                        Attention, \D and \d are different.
                        \d is a digit
                        \D is not a digit
                        More about regex and its syntax can be seen here.
                          What the heck!
