    Ctrl + e and ctrl + shift + alt not working
    5 Posts 3 Posters 5.1k Views 1 Watching
    • 1236987411 Offline
      123698741
      When I press ctrl + e a character like ENQ appears in a rectangle, instead of autocompleting a tag.
      And just when I press ctrl + shift + alt nothing happens
      • Alan KilbornA Online
        Alan Kilborn @123698741
        @123698741 said in Ctrl + e and ctrl + shift + alt not working:
        What key-combination is the “autocompleting a tag” command set to in the Shortcut Mapper ?
        What is command is “ctrl+e” set to in the Shortcut Mapper ? (I suspect nothing because otherwise a black-boxed ENQ would NOT appear.)
        and just when I press ctrl + shift + alt nothing happens
        You mean only those 3 keys? If so, then you’re right, nothing happens (because nothing is supposed to).
        BTW, if you want to know more about ctrl+e, here’s some light reading for you:
        datatraveller1D 1 Reply Last reply Reply Quote 4
        • datatraveller1D Offline
          datatraveller1 @Alan Kilborn
          Hi @Alan-Kilborn,
          Thank you very much for your great answer.
          I would prefer if Ctrl+E printed nothing (like notepad). Pressing Shift+Ctrl+E also prints ENQ and Shift+Ctrl+B prints STX. At least the combinations with Shift should not cause to trigger these control characters. What do you think about it?
            Alan Kilborn @datatraveller1
            @datatraveller1
            would prefer if Ctrl+E printed nothing. Pressing Shift+Ctrl+E also prints ENQ and Shift+Ctrl+B prints STX. At least the combinations with Shift should not cause to trigger these control characters. What do you think about it?
            Well, I basically agree with that, and I’ve long had a script that filters control characters out in case I “fat finger” one that isn’t assigned to a shortcut keycombo in Notepad++.
            It seems like this topic has been discussed in the Community before, but it was so long ago I can’t find the reference.
            But anyway, you can achieve your desire if you are willing to use the PythonScript plugin and set up the following simple script:
            # -*- coding: utf-8 -*-
            from Npp import *
            def modified_callback(args):
                if args['modificationType'] == MODIFICATIONFLAGS.INSERTCHECK:
                    t = args['text']
                    if len(t) > 1: return
                    if ord(t) in range(0, 0x1F + 1) and t not in '\t\n\r':
                        editor.changeInsertion('')
            editor.callbackSync(modified_callback, [SCINTILLANOTIFICATION.MODIFIED])  # must be callbackSync!
            Some notes on PythonScript are found HERE.
              Alan Kilborn @Alan Kilborn
              Note that in Notepad++ 8.5 and later, Shift+Ctrl+B is the default keycombo for Begin/End Select :
              So this keycombo will no longer insert a STX character into documents when typed.
