    Editor right-click, outside current text selection, lose this selection
    35 Posts 6 Posters 22.6k Views 1 Watching
    • frying-panF Offline
      frying-pan
      Oops, I forgot to delete 3 lines of old code (at line 141 of the script). But I can’t modify any more the previous post.
      So the code updated without the bug :
      # PythonScript which hooks mouse clicks (WndProc HOOK on Scintilla windows)
      # * SHIFT + double left mouse click : select text from click point until next space/space-like chars : \s
      # * right mouse click : prevent right-click from moving the caret and losing current text selection
      # re-run the script to de-activate/re-activate the hook
      # Tested on NPP 64 bits (NOT tested on 32 Bits but could be compatible), /!\ this file uses TABS for indent
      from Npp import *
      import platform
      import ctypes
      from ctypes import wintypes
      import datetime
      from datetime import datetime
      s_script_name			= "Perso_ScintWndProc_Hook"
      s_hook_name				= "Scint_Mouse_Click_Hook"
      s_editorprop_regdone	= "SCINTWNDPROCHOOK_DONE"
      s_editorprop_active		= "SCINTWNDPROCHOOK_ACTIVE"
      s_true					= "TRUE"
      GWL_WNDPROC = -4				# used to set a new address for the windows procedure
      I_VK_SHIFT		= 0x10			# SHIFT virtual key code
      I_VK_CONTROL	= 0x11			# CONTROL virtual key code
      I_VK_ALT		= 0x12			# ALT virtual key code
      KSTATE_ISDOWN = 0x8000			# key pressed
      WM_LBUTTONDBLCLK	= 0x0203	# double left mouse click window message
      WM_RBUTTONDOWN		= 0x0204	# right mouse click window message
      LRESULT = wintypes.LPARAM
      WndProcType = ctypes.WINFUNCTYPE(LRESULT, wintypes.HWND, wintypes.UINT, wintypes.WPARAM, wintypes.LPARAM)
      # window message hook functions
      CallWindowProc = ctypes.windll.user32.CallWindowProcW
      CallWindowProc.restype = LRESULT
      CallWindowProc.argtypes = [WndProcType, wintypes.HWND, wintypes.UINT, wintypes.WPARAM, wintypes.LPARAM]
      x86 = platform.architecture()[0] == "32bit"
      if x86:
      	SetWindowLong = ctypes.windll.user32.SetWindowLongW
      else:
      	SetWindowLong = ctypes.windll.user32.SetWindowLongPtrW
      SetWindowLong.restype = WndProcType
      SetWindowLong.argtypes = [wintypes.HWND, wintypes.INT, WndProcType]
      # end of window message hook functions
      EnumWindowsProc				= ctypes.WINFUNCTYPE(wintypes.BOOL, wintypes.HWND, wintypes.LPARAM)
      EnumWindows					= ctypes.windll.user32.EnumWindows
      EnumChildWindows			= ctypes.windll.user32.EnumChildWindows
      RealGetWindowClass			= ctypes.windll.user32.RealGetWindowClassW
      GetWindowThreadProcessId	= ctypes.windll.user32.GetWindowThreadProcessId
      GetCurrentProcessId			= ctypes.windll.kernel32.GetCurrentProcessId
      GetLastError				= ctypes.windll.kernel32.GetLastError
      SetLastError				= ctypes.windll.kernel32.SetLastError
      GetAsyncKeyState = ctypes.windll.user32.GetAsyncKeyState # used to check if a modifier key is pressed
      class C_Scint_Mouse_Click_Hook(): # hook class
      	# class constructor
      	def __init__(self):
      		def Enum_Window_Hwnd(hwnd, lParam):
      			arr_enum_window_hwnd.append(hwnd)
      			return True
      		s_npp_class		= u"Notepad++"
      		s_scint_class	= u"Scintilla"
      		self.arr_scint_hwnd = []
      		self.npp_win_hwnd = 0
      		i_cur_pid = GetCurrentProcessId()
      		arr_enum_window_hwnd = []
      		EnumWindows(EnumWindowsProc(Enum_Window_Hwnd), 0)
      		# enum all class="Notepad++" NPP window handles
      		buff = ctypes.create_unicode_buffer(len(s_npp_class) + 1 + 1)
      		for win_hwnd in arr_enum_window_hwnd:
      			RealGetWindowClass(win_hwnd, buff, len(s_npp_class) + 1 + 1)
      			if buff.value == s_npp_class:
      				# check that found NPP window handle is owned by current process, stop at the first found
      				ci_win_pid = wintypes.DWORD(0)
      				GetWindowThreadProcessId(win_hwnd, ctypes.pointer(ci_win_pid))
      				if i_cur_pid == ci_win_pid.value:
      					self.npp_win_hwnd = win_hwnd
      					break
      		if self.npp_win_hwnd == 0:
      			return
      		del arr_enum_window_hwnd[:]
      		EnumChildWindows(self.npp_win_hwnd, EnumWindowsProc(Enum_Window_Hwnd), 0)
      		# enum all class="Scintilla" window handles, childs of NPP window
      		# get all of them in arr_scint_hwnd (at least all existing ones at that time)
      		buff = ctypes.create_unicode_buffer(len(s_scint_class) + 1 + 1)
      			RealGetWindowClass(win_hwnd, buff, len(s_scint_class) + 1 + 1)
      			if buff.value == s_scint_class:
      				self.arr_scint_hwnd.append(win_hwnd)
      	def RegHook(self):															# function to register the hook on all found Scintilla windows
      		if (self.npp_win_hwnd == 0 or len(self.arr_scint_hwnd) == 0):			# abort if no NPP handle or no Scintilla handle
      			return
      		self.NewWndProc = WndProcType(self.MyWndProc)							# get the address of our own WndProc
      		self.arr_scint_oldwndproc = []
      		s_list = "\t" + "Found " + str(len(self.arr_scint_hwnd)) + " " + s_scint_class + " Handle / WindowProc"
      		for i in range(0, len(self.arr_scint_hwnd)):
      			win_hwnd = self.arr_scint_hwnd[i]
      			SetLastError(0)
      			oldwndproc = SetWindowLong(win_hwnd, GWL_WNDPROC, self.NewWndProc)	# register and store oldwndproc addresses in arr_scint_oldwndproc
      			i_apierr = GetLastError()
      			if i_apierr == 0:
      				self.arr_scint_oldwndproc.append(oldwndproc)
      				s_list = s_list + "\n" + "\t\t" + hex(win_hwnd) + " / " + str(oldwndproc)
      			else:
      				del self.arr_scint_hwnd[i]
      				s_list = s_list + "\n" + "\t\t" + hex(win_hwnd) + " / " + "NO WindowProc, NOT hooked"
      		print "\t" + s_npp_class + " Handle = " + hex(self.npp_win_hwnd) + "\n" + s_list
      	def MyWndProc(self, hWnd, msg, wParam, lParam):							# our own WndProc function receives windows messages
      		oldwndproc = 0
      			if self.arr_scint_hwnd[i] == hWnd:								# target hWnd found at index i in arr_scint_hwnd
      				oldwndproc = self.arr_scint_oldwndproc[i]					# corresponding oldwndproc is picked in arr_scint_oldwndproc
      				break
      		if oldwndproc == 0:													# fatal error ! should not happen...
      			print "\t" + s_hook_name + " Fatal error ! oldwndproc = 0"
      			notepad.messageBox(s_hook_name + " Fatal error ! oldwndproc = 0", s_script_name)
      			return 0
      		if (msg != WM_LBUTTONDBLCLK and msg != WM_RBUTTONDOWN):				# if NOT mouse hooked messages : abort
      			return CallWindowProc(oldwndproc, hWnd, msg, wParam, lParam)	# -> IMPORTANT pass other msg to NPP, otherwise will block NPP
      		if console.editor.getProperty(s_editorprop_active) != s_true:		# if hook de-activated : abort
      		b_shift_down	= ((GetAsyncKeyState(I_VK_SHIFT)	& KSTATE_ISDOWN) == KSTATE_ISDOWN)
      		b_ctrl_down		= ((GetAsyncKeyState(I_VK_CONTROL)	& KSTATE_ISDOWN) == KSTATE_ISDOWN)
      		b_alt_down		= ((GetAsyncKeyState(I_VK_ALT)		& KSTATE_ISDOWN) == KSTATE_ISDOWN)
      		if (msg == WM_LBUTTONDBLCLK and b_shift_down and not(b_ctrl_down) and not(b_alt_down)):
      			self.ExtendSelToSpaceLikeChars()								# extend selection from the clicked point to the space-like chars
      		elif (msg == WM_RBUTTONDOWN and not(b_shift_down) and not(b_ctrl_down) and not(b_alt_down)):
      			dummy = 0														# do nothing
      		else:
      		#res = "DEBUG " + s_hook_name
      		#res = res + " Message = " + hex(msg) + " to hWnd = " + hex(hWnd)
      		#res = res + " Forwarded To oldwndproc = " + str(oldwndproc)
      		#print res + " At " + str(datetime.now())
      		return CallWindowProc(oldwndproc, hWnd, 0, 0, 0)					# nullify the mouse hooked messages
      	def ExtendSelToSpaceLikeChars(self):
      		# space-like chars are space/tab/carriage return/line feed/form feed... [\t\n\x0B\f\r\x20\x85\xA0\x{2028}\x{2029}]
      		editor.searchAnchor()
      		i_start = editor.searchPrev(FINDOPTION.REGEXP, "\s")
      		i_start = i_start + 1
      		if i_start < 0:
      			i_start = 0
      		i_end = editor.searchNext(FINDOPTION.REGEXP, "\s")
      		if i_end < 0:
      			i_end = editor.getTextLength()
      		editor.setSel(i_start, i_end)
      print "[" + s_script_name + " starts]"
      if console.editor.getProperty(s_editorprop_regdone) != s_true:
      	console.editor.setProperty(s_editorprop_regdone, s_true)
      	console.editor.setProperty(s_editorprop_active, s_true)
      	o_scint_mouse_click_hook = C_Scint_Mouse_Click_Hook()	# create an instance of hook class
      	o_scint_mouse_click_hook.RegHook()						# set up the mouse hook
      	print "\t" + s_hook_name + " registered and ACTIVATED (re-run script to toggle the hook)"
      else:
      		print "\t" + s_hook_name + " RE-ACTIVATED (re-run script to toggle the hook)"
      		notepad.messageBox(s_hook_name + " RE-ACTIVATED\n(re-run script to toggle the hook)", s_script_name)
      	else:
      		console.editor.setProperty(s_editorprop_active, "")
      		print "\t" + s_hook_name + " de-activated (re-run script to toggle the hook)"
      		notepad.messageBox(s_hook_name + " de-activated\n(re-run script to toggle the hook)", s_script_name)
        frying-pan @frying-pan
          frying-pan
          Code update, probably the last for this script, since I have all the keyboard + mouse shortcuts I need.
          • corrected one bug :
            (in case of a Scintilla window hook failure, the list of hooked WndProcs was incorrectly shortened and enumerated)
          • cleaned the code
          • added more keyboard + mouse shortcuts :
            • SHIFT + double-left-click : select from clicked point the whole variable name : alphanumeric with _ and . (dot)
            • CTRL + SHIFT + double-left-click : select from clicked point the whole bracket content : () [] {}, from left in case of mismatch
            • ALT + SHIFT + double-left-click : select from clicked point the whole quote content : “” ‘’, from left in case of mismatch
            • ALT + right-click : select from clicked point until space/space-like characters are met : space/tab/cr/lf/formfeed/vtab etc…
            • right-click : prevent right-click from moving the caret and losing current text selection
          • added options to disable each shortcut separately (these options values must be edited in the script file)
          note : my code rendering would be better if I could set up the real tabs to appear as 4 chars wide on this forum
          (I prefer to have 4 chars wide tabs in Notepad++ but this forum render them as 8 chars wide)
          note: since the code is too long to be loaded in one post, it will posted in two chunks.
          Code chunk 1/2:
          # Tested on Notepad++ 64 bits (NOT tested on 32 Bits but could be compatible) /!\ this file uses TABS for indent /!\
          	# SHIFT + double-left-click			: select from clicked point the whole variable name : alphanumeric with _ and . (dot)
          	# CTRL + SHIFT + double-left-click	: select from clicked point the whole bracket content : () [] {}, from left in case of mismatch
          	# ALT + SHIFT + double-left-click	: select from clicked point the whole quote content : "" '', from left in case of mismatch
          	# ALT + right-click					: select from clicked point until space/space-like characters are met : space/tab/cr/lf/formfeed/vtab etc...
          	# right-click						: prevent right-click from moving the caret and losing current text selection
          # re-run the script to de-activate/re-activate the whole hook (re-running the script will also apply new *options values*)
          # change the *options values* (just below) to choose which mouse hooks will be active
          # *options values* : set value to INTEGER 1 to have the feature enabled (any OTHER INTEGER value will DISABLE it)
          i_feature_shift_double_left_click			= 1
          i_feature_control_shift_double_left_click	= 1
          i_feature_alt_shift_double_left_click		= 1
          i_feature_alt_right_click					= 1
          i_feature_right_click						= 1
          i_message_box_warnings						= 1	# if disabled, no message box will pop on registering hook error,
          												# or when toggling the hook (console messages will still occur)
          # end of *options values*
          from Npp import *
          import platform
          import ctypes
          import datetime
          s_editorprop_regdone		= "SCINTWNDPROC_HOOK_DONE"
          s_editorprop_active			= "SCINTWNDPROC_HOOK_ACTIVE"
          s_editorprop_sdlc_active	= "SCINTWNDPROC_SDLC_ACTIVE"
          s_editorprop_csdlc_active	= "SCINTWNDPROC_CSDLC_ACTIVE"
          s_editorprop_asdlc_active	= "SCINTWNDPROC_ASDLC_ACTIVE"
          s_editorprop_arc_active		= "SCINTWNDPROC_ARC_ACTIVE"
          s_editorprop_rc_active		= "SCINTWNDPROC_RC_ACTIVE"
          s_true						= "TRUE"
          s_reruntogglehook	= "Re-run the script to toggle the whole hook"
          s_willapplynewopt	= "This will also apply new *options values* saved in the script file"
          s_feature_sdlc_off	= "* Feature SHIFT + double-left-click is DISABLED by script option"
          s_feature_csdlc_off	= "* Feature CTRL + SHIFT + double-left-click is DISABLED by script option"
          s_feature_asdlc_off	= "* Feature ALT + SHIFT + double-left-click is DISABLED by script option"
          s_feature_arc_off	= "* Feature ALT + right-click is DISABLED by script option"
          s_feature_rc_off	= "* Feature right-click is DISABLED by script option"
          WM_LBUTTONDBLCLK	= 0x0203	# mouse double-left-click window message
          WM_RBUTTONDOWN		= 0x0204	# mouse right-click down window message
          WM_RBUTTONUP		= 0x0205	# mouse right-click up window message
          if x86:
          else:
          	# class constructor
          	def __init__(self):
          	def RegHook(self):
          		def Enum_Window_Hwnd(hwnd, lparam):
          			return True
          		npp_win_hwnd = None
          		# get all class="Notepad++" top_level NPP windows handle
          				# check if each NPP window handle is owned by current process, stop at the first found
          					break
          		if npp_win_hwnd is None:
          			print "\t" + s_npp_class + " window NOT found ! NO hook !"
          			return False
          		print "\t" + s_npp_class + " Handle = " + hex(npp_win_hwnd)
          		EnumChildWindows(npp_win_hwnd, EnumWindowsProc(Enum_Window_Hwnd), 0)
          		# get all class="Scintilla" windows handle, childs of NPP window, in arr_scint_hwnd
          		# (at least all existing Scintilla windows at that time, should include primary and secondary views)
          		self.newWndProc = WndProcType(self.MyWndProc)
          		# register the hook for each window present in arr_scint_hwnd
          		i_index = 0
          		while i_index < len(self.arr_scint_hwnd):
          			win_hwnd = self.arr_scint_hwnd[i_index]
          			# register hook and store oldwndproc addresses in arr_scint_oldwndproc
          			SetLastError(0)
          			oldwndproc = SetWindowLong(win_hwnd, GWL_WNDPROC, self.newWndProc)
          			if i_apierr == 0:
          				i_index = i_index + 1
          			else:
          				del self.arr_scint_hwnd[i_index]
          				s_list = s_list + "\n" + "\t\t" + hex(win_hwnd) + " / " + "NO WindowProc ! NOT hooked !"
          		print s_list
          		if len(self.arr_scint_hwnd) == 0:
          			print "\t" + s_scint_class + " window(s) or WindowProc(s) NOT found ! NO hook !"
          			return False
          		return True
          	def MyWndProc(self, hwnd, msg, wparam, lparam):							# our own WndProc function receives windows messages
          		oldwndproc = None
          			if self.arr_scint_hwnd[i] == hwnd:								# target hwnd found at index i in arr_scint_hwnd
          				break
          		if oldwndproc is None:												# fatal error ! should not happen...
          			print "\t" + s_hook_name + " Fatal error ! Hooked WndProc NOT found !"
          			notepad.messageBox(s_hook_name + " Fatal error ! Hooked WndProc NOT found !", s_script_name, MESSAGEBOXFLAGS.ICONEXCLAMATION)
          			return 0
          		if (msg != WM_LBUTTONDBLCLK and msg != WM_RBUTTONDOWN and msg != WM_RBUTTONUP): # if NOT in mouse hooked messages : abort
          			return CallWindowProc(oldwndproc, hwnd, msg, wparam, lparam)	# -> IMPORTANT pass other msg to NPP, otherwise will block NPP
          		if (console.editor.getProperty(s_editorprop_sdlc_active) == "1" and \
          			self.ExtendSel_AlphaNumUnderscoreDot()							# select from clicked point the whole variable name
          		if (console.editor.getProperty(s_editorprop_csdlc_active) == "1" and \
          				msg == WM_LBUTTONDBLCLK and b_shift_down and b_ctrl_down and not(b_alt_down)):
          			self.ExtendSel_BracketContent()									# select from clicked point the whole bracket content
          		if (console.editor.getProperty(s_editorprop_asdlc_active) == "1" and \
          				msg == WM_LBUTTONDBLCLK and b_shift_down and not(b_ctrl_down) and b_alt_down):
          			self.ExtendSel_Quotes()											# select from clicked point the whole quote content
          		elif (console.editor.getProperty(s_editorprop_arc_active) == "1" and \
          				msg == WM_RBUTTONUP and not(b_shift_down) and not(b_ctrl_down) and b_alt_down):
          			self.ExtendSel_SpaceSpaceLike()
          		elif (console.editor.getProperty(s_editorprop_rc_active) == "1" and \
          		else:
          		#res = res + " Message = " + hex(msg) + " to hwnd = " + hex(hwnd)
          		return CallWindowProc(oldwndproc, hwnd, 0, 0, 0)					# nullify the mouse hooked messages
            frying-pan
            Code chunk 2/2:
            	def FindBorderBiDir(self, i_start, s_pattern):
            		i_text_len = editor.getTextLength()
            		t_search = editor.findText(FINDOPTION.REGEXP, i_start, 0, s_pattern)
            		if t_search is None:
            			i_left = -1
            		else:
            			i_left = t_search[0]
            		t_search = editor.findText(FINDOPTION.REGEXP, i_start, i_text_len, s_pattern)
            			i_right = i_text_len
            		else:
            			i_right = t_search[0]
            		return (i_left, i_right)
            	def ExtendSel_SpaceSpaceLike(self):
            		s_pattern = "\s"
            		i_caret_pos = editor.getCurrentPos()
            		i_start	= editor.getSelectionStart()
            		i_end	= editor.getSelectionEnd()
            		t_border = self.FindBorderBiDir(i_caret_pos, s_pattern)
            		i_left	= t_border[0] + 1
            		i_right	= t_border[1]
            		if i_left < i_right:
            			editor.setSel(i_left, i_right)
            		else:
            	def ExtendSel_AlphaNumUnderscoreDot(self):
            		s_pattern = "[^\w_.]"
            		else:
            	def ExtendSel_Quotes(self):
            		t_search_prev_single = editor.findText(0, i_caret_pos, 0, "'")
            		t_search_next_single = editor.findText(0, i_caret_pos, i_text_len, "'")
            		t_search_prev_double = editor.findText(0, i_caret_pos, 0, chr(34))
            		t_search_next_double = editor.findText(0, i_caret_pos, i_text_len, chr(34))
            		i_left	= None
            		i_right	= None
            		if ((t_search_prev_single is None) or (t_search_next_single is None)):
            			if (not(t_search_prev_double is None) and not(t_search_next_double is None)):
            				i_left	= t_search_prev_double[0] + 1
            				i_right	= t_search_next_double[0]
            		elif ((t_search_prev_double is None) or (t_search_next_double is None)):
            			if (not(t_search_prev_single is None) and not(t_search_next_single is None)):
            				i_left	= t_search_prev_single[0] + 1
            				i_right	= t_search_next_single[0]
            		elif t_search_prev_single[0] < t_search_prev_double[0]:
            		elif t_search_prev_double[0] < t_search_prev_single[0]:
            		if (not(i_left is None) and not(i_right is None)):
            		else:
            	def ExtendSel_BracketContent(self):
            		def SearchOrphan(i_start, i_end, s_pattern_brackets):
            			if i_start == i_end:
            				return None
            			if i_start < i_end: b_forward = True
            			else: b_forward = False
            			i_par = 0; i_sqr = 0; i_cur = 0
            			i_pos = i_start
            			while True:
            				t_search = editor.findText(FINDOPTION.REGEXP, i_pos, i_end, s_pattern_brackets)
            					return None
            				i_pos = t_search[0]
            				s_char = editor.getTextRange(i_pos, i_pos + 1)
            				if		s_char == "(": i_par += 1
            				elif	s_char == ")": i_par -= 1
            				elif	s_char == "[": i_sqr += 1
            				elif	s_char == "]": i_sqr -= 1
            				elif	s_char == "{": i_cur += 1
            				elif	s_char == "}": i_cur -= 1
            				if b_forward:
            					if (i_par < 0 or i_sqr < 0 or i_cur < 0): break
            				else:
            					if (i_par > 0 or i_sqr > 0 or i_cur > 0): break
            				if b_forward: i_pos = i_pos + 1
            			return (i_pos, s_char)
            		s_pattern_par = "\(\)"
            		s_pattern_sqr = "\[\]"
            		s_pattern_cur = "\{\}"
            		s_pattern_brackets = "[" + s_pattern_par + s_pattern_sqr + s_pattern_cur + "]"
            		i_left	= None
            		i_right	= None
            		while True:
            			t_orphan_back = SearchOrphan(i_caret_pos, 0, s_pattern_brackets)
            			if t_orphan_back is None: break
            			s_char = t_orphan_back[1]
            			if		s_char == "(": s_pattern = "[" + s_pattern_par + "]"
            			elif	s_char == "[": s_pattern = "[" + s_pattern_sqr + "]"
            			elif	s_char == "{": s_pattern = "[" + s_pattern_cur + "]"
            			t_orphan_forward = SearchOrphan(i_caret_pos, i_text_len, s_pattern)
            			if not(t_orphan_forward is None):
            				i_left	= t_orphan_back[0] + 1
            				i_right	= t_orphan_forward[0]
            				break
            			if		s_char == "(": s_pattern_brackets = s_pattern_brackets.replace(s_pattern_par, "")
            			elif	s_char == "[": s_pattern_brackets = s_pattern_brackets.replace(s_pattern_sqr, "")
            			elif	s_char == "{": s_pattern_brackets = s_pattern_brackets.replace(s_pattern_cur, "")
            			if s_pattern_brackets == "[]": break
            		else:
            	# end of class
            s_opt_info = ""
            if i_feature_shift_double_left_click			!= 1: s_opt_info = s_opt_info + "\t" + s_feature_sdlc_off + "\n"
            if i_feature_control_shift_double_left_click	!= 1: s_opt_info = s_opt_info + "\t" + s_feature_csdlc_off + "\n"
            if i_feature_alt_shift_double_left_click		!= 1: s_opt_info = s_opt_info + "\t" + s_feature_asdlc_off + "\n"
            if i_feature_alt_right_click					!= 1: s_opt_info = s_opt_info + "\t" + s_feature_arc_off + "\n"
            if i_feature_right_click						!= 1: s_opt_info = s_opt_info + "\t" + s_feature_rc_off + "\n"
            if not(s_opt_info == ""): s_opt_info = s_opt_info[:-1]
            console.editor.setProperty(s_editorprop_sdlc_active,	str(i_feature_shift_double_left_click))
            console.editor.setProperty(s_editorprop_csdlc_active,	str(i_feature_control_shift_double_left_click))
            console.editor.setProperty(s_editorprop_asdlc_active,	str(i_feature_alt_shift_double_left_click))
            console.editor.setProperty(s_editorprop_arc_active,		str(i_feature_alt_right_click))
            console.editor.setProperty(s_editorprop_rc_active,		str(i_feature_right_click))
            	o_scint_mouse_click_hook = C_Scint_Mouse_Click_Hook()	# create an instance of the hook class
            	b_reg = o_scint_mouse_click_hook.RegHook()				# register the hook on all found Scintilla windows
            	if b_reg:
            		print "\t" + s_hook_name + " registered and activated (" + s_reruntogglehook + ")"
            		if not(s_opt_info == ""): print s_opt_info
            	else:
            		print "\t" + s_hook_name + " registering failed"
            		if i_message_box_warnings == 1:
            			notepad.messageBox(s_hook_name + " registering failed", s_script_name, MESSAGEBOXFLAGS.ICONSTOP)
            else:
            		print "\t" + s_hook_name + " re-activated (" + s_reruntogglehook + ")"
            			notepad.messageBox( \
            				s_hook_name + " re-activated\n\n" + s_reruntogglehook + "\n" + s_willapplynewopt + "\n" + s_opt_info, \
            				s_script_name, MESSAGEBOXFLAGS.ICONINFORMATION)
            	else:
            		print "\t" + s_hook_name + " DE-ACTIVATED (" + s_reruntogglehook + ")"
            				s_hook_name + " DE-ACTIVATED\n\n" + s_reruntogglehook + "\n" + s_willapplynewopt + "\n" + s_opt_info, \
              frying-pan
              Hey ! the forum changed the line 313 of my uploaded code
              line 313 was uploaded as :
              (I must replace \ by BKL to have it displayed)
              s_pattern_sqr = “BKL[BKL]”
              but is displayed without the \ as :
              s_pattern_sqr = “[]”
              which breaks the ‘CTRL + SHIFT + double-left-click’ feature : select brackets content : () [] {}
              having compared the whole uploaded code with my original code there should no other error
              (I used a simple file compare utility to do that : ExamDiff)
              So there is a bug in the text parser of the forum :
              the preview is ok but the final post has lost the backslashes
              Michael VincentM Alan KilbornA 2 Replies Last reply Reply Quote 1
              • Michael VincentM Offline
                Michael Vincent @frying-pan
                @frying-pan
                Wow, that’s quite a script. Maybe post to GitHub or a Gist and then link from here to that post?
                Cheers.
                frying-panF 1 Reply Last reply Reply Quote 0
                  Alan Kilborn @frying-pan
                    frying-pan @Michael Vincent
                    @Michael-Vincent
                    Uploaded on GitHub the last posted script in this thread, as version v1 (without the backslash error)
                    [https://github.com/frying-pan/NotepadPP-PythonScript-Mouse-Gesture/blob/master/Perso_ScintWndProc_Hook.v1.py](link url)
                    and made a version v2.0 : with some code cleaning and more object_oriented style
                    [https://github.com/frying-pan/NotepadPP-PythonScript-Mouse-Gesture/blob/master/Perso_ScintWndProc_Hook.v2.0.py](link url)
                    frying-panF 1 Reply Last reply Reply Quote 2
                      @frying-pan
                      Because of file name changes, above links are not valid any more,
                      see below for new links to each repository.
                        frying-pan
                        An update of :
                        Perso_ScintWndProc_Hook_v1_0.py to Perso_ScintWndProc_Hook_v1_1.py and
                        Perso_ScintWndProc_Hook_v2_0.py to Perso_ScintWndProc_Hook_v2.1.py for the same small bug
                        Update to Perso_ScintWndProc_Hook_v3_0.py with new features :
                        • option to select brackets/quotes with content
                        • option to auto-copy selection to clipboard and/or console
                        • expand selection from a previous selection
                          -> now requires the two libraries : Perso__Lib_Edit.py, Perso__Lib_Window.py
                        all files provided in the GitHub repository :
                        And another small python script to tweak the CR and LF graphic :
                        these changes can be applied at each Notepad++ start by running the script from startup.py
                        Perso_CrLfDisplay_Callback_v1_0.py
                        file provided in the GitHub repository :
                        https://github.com/frying-pan/NotepadPP-PythonScript-CrLf-Graphic-Tweak
                          frying-pan
                          I take advantage of this thread to advertise about two other python scripts that I wrote:
                          Bracket Indicator : highlight the bracket () [] {} where is the selection/caret
                          based on BracketHighlighter.py idea, with easier customization for highlight style,
                          a different algo for highlighting (using the ‘re’ regexp object, possibly more efficient),
                          following the brackets matching rules of Scintilla
                          RestartNPP : to restart Notepad++ remembering the current session (opened file),
                          can possibly made into a button, and be run with a keyboard shortcut via ‘Shortcut Mapper’
                          can be handy when developping a script/plugin
                          Perso_ScintWndProc_Hook was renamed to FP_MouseSelectGest_Hook, and updated
                          Perso_CrLfDisplay_Callback was renamed to FP_CrLfDisplay_Callback, and updated
                          FP_MouseSelectGest_Hook, FP_BracketIndicator_Callback and FP_CrLfDisplay_Callback
                          can be run from startup.py on each NPP start (with pythonscript option : initialisation=ATSTARTUP)
                          All four scripts have options at the top of the main script file that can be changed by the user
                          Some of these scripts use libraries which are provided in the same Github folder as the main script
                          Here is the root of the Github repositories :
                          https://github.com/frying-pan?tab=repositories
                          and the four repositories for the four scripts :
                          https://github.com/frying-pan/NotepadPP-PythonScript-Mouse_Select_Gesture
                          https://github.com/frying-pan/NotepadPP-PythonScript-Bracket_Indicator
                          https://github.com/frying-pan/NotepadPP-PythonScript-Restart_NotepadPP
                          https://github.com/frying-pan/NotepadPP-PythonScript-CrLf_Display
                            This thread got rather out of control.
                            Anyway, I’m back to say that I did change my mind and I like the very first basic functionality this thread introduced: The ability to not lose your selection if you right click somewhere not on that selection.
                            However, I noticed that it isn’t compatible with one of the new features of Notepad++: The ability go right-click the bookmark margin and get a right-click popup menu of bookmarking functions.
                            I like the idea of both features; I wonder if there is some way to get both functionalities. Hmmm…
                              frying-pan @Alan Kilborn
                              “This thread got rather out of control.”
                              I could create a separate thread to describe and post the links for the 4 scripts I have made available on Github
                              “However, I noticed that it isn’t compatible with one of the new features of Notepad++: The ability go right-click the bookmark margin and get a right-click popup menu of bookmarking functions.”
                              I have NPP 7.8.2 and the right-click on the bookmark margin has been introduced later, so I can not test this for the moment
                              (I guess the right-click context-menu on the bookmark margin does not appear at all…)
                              I could discriminate between right-clicks on the margin or the text by pixel position,
                              I will need the widths in pixels of all left margins :
                              the function “editor.getMarginWidthN(margin_index) → int”, gives that for each margin_index,
                              but I don’t know how many of margin_indexes must be checked (probably 5, from 0 to SC_MAX_MARGIN (4)),
                              the function SCI_GETMARGINS (that gives the number of margins) seems to be missing from the NPP Scintilla commands
                              Possible workarounds :
                              My script does not intercept shift+right-click, so it could be tried on the bookmark margin
                              (in case this context-menu is not sensitive to the shift key, which is often the case for context-menus)
                              Also control+right-click and alt+right-click can be disabled in my script
                              (there is a middle-click alternative for these features)
                              to see if they trigger the bookmark margin context-menu, which seems less likely…
                                @frying-pan
                                I noticed that the feature that this thread started with is being implemented natively in Notepad++. See HERE.
                                frying-panF 1 Reply Last reply Reply Quote 1
                                  ok i see
                                  [https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8564](link url)
                                  ‘Keep selection when right-click outside of selection’ has been added, or will be added to the next NPP version (as an option).
                                  So I will remove this specific feature from my
                                  NotepadPP-PythonScript-Mouse_Select_Gesture script
                                  once I have updated my NPP and tested the native option.
