    Problem to open CSV. Formt looks differnt
    1 Posts 1 Posters 555 Views 1 Watching
    • fmni2F Offline
      fmni2
      I have some problems opening csv and txt files. When I export a file as csv or txt notepad, the data opens in one column. When I open the same file in Excel, all columns are imported correctly. Likewise, if I save the file under a other name as csv or txt, when I open the file the same thing happens. All data in one column. I add a screenshot to show my problem.
      The first screenshot shows when I open the csv file.
      The second picture shows how I should look like.
      Third picture, opening the same file in Excel.
      What is the problem? Yesterday and the day before I worked without problems.
      Second image, how I shoud look like.
      Third image, same file open in Exel.
      What’s the problem . Yesterday and the day befor I workded without problem.
