    Problem with converting lowercase to uppercase
    12 Posts 5 Posters 1.9k Views 1 Watching
    • Thomas 2020T Offline
      Thomas 2020
      I see good RegEx specialists here,
      maybe I can solve the problem here.
      I want to replace:
      Mckenzie, Mccoy, mcdonalds
      on:
      McKenzie, McCoy, McDonalds
      Find: Mc([a-z])|mc([A-z])
      Replace: Mc\u$1$2
      I’m using a different editor, and RegEx doesn’t use \u or \l there
      and it comes out like this:
      Mc￿enzie, Mc￿oy, Mc￿onalds
      Can you do it without this “\u”?
        PeterJones @Thomas 2020
        @Pan-Jan said in Problem with converting lowercase to uppercase:
        This forum isn’t a generic regex help site. If you are using a different editor, ask in their forum, or find a regex help site (generic, or specific to the regex engine used by your editor).
          Hello, @pan-jan and All,
          Try this regex S/R :
          SEARCH (?i)\bMc([[:alpha:]])
          REPLACE Mc\u$1
          which changes any form, as below :
          mcDonalds
          McDonalds
          mCDonalds
          MCDonalds
          mcdonalds
          Mcdonalds
          mCdonalds
          MCdonalds
          with the unique good syntax :
          McDonalds
          Notes :
          • The (?i) in-line modifier carries the search in an insensitive way
          • The [[:alpha:]] POSIX class range represents any single uppercase or lowercase letter
          • In replacement, the \u syntax rewrites the next letter, stored in group 1, in uppercase
          BR
            Thomas 2020
            @guy038 said in Problem with converting lowercase to uppercase:
            the \u syntax
            just the
            \u
            syntax doesn’t work
              Hello @pan-jan and All,
              I’m really sorry but the regex syntax \u, in replacement, does do the job ! That is to say it capitalizes the first letter of the following string or group !
              For instance :
              SEARCH (?-i)foo
              REPLACE \ubar
              changes the word foo, with this exact case, by Bar
              And :
              SEARCH (?-i)(foo|bar)
              REPLACE \u$1
              would change the words foo and bar , with this exact case, by the words Foo and Bar
                Ekopalypse @guy038
                @guy038
                maybe you missed @PeterJones comment and OPs info?
                  Hi @ekopalyse,
                  Ah… OK. So, what’s he waiting for to switch to Notepad++ ;-)))
                  BR
                    Thomas 2020
                    Thank you but…
                    AkelPad is much better than Notepad ++.
                      Hi, @pan-jan,
                      If so, why don’t you join the Akelpad community and find out a solution, from within this software, or, may be, ask the Akelpad’s author to improve the regex engine ?
                      BR
                        Thomas 2020
                        I asked before.
                        No response means nothing can be done.
                        I see there are some good RegEx specialists here
                        and I’m trying to solve the problem here.
                        • mkupperM Offline
                          mkupper
                          Implementation of regex varies from one application to the next.
                          It’s a guess based on the OP’s results but it seems that \u in the OP’s editor is the lead-in for Unicode related stuff such as \u0025 for a percent (%) sign. The OP’s examples have \xFFFF characters in them.
                          Fiddling with people’s names seems dangerous as there are people who have Mc… style surnames where the third character is not upper-case. If there is a requirement to make the names a consistent case then convert everything to upper case.
                          I think we are in https://community.notepad-plus-plus.org/topic/15958/faq-desk-you-ve-asked-your-question-in-the-wrong-place territory.
                            Thomas 2020
                            @mkupper said in Problem with converting lowercase to uppercase:
                            e.g?
