    Problem with cursor position
    16 Posts 4 Posters 7.9k Views
    • Alter GraubartA Offline
      Alter Graubart
      Whenever I past a text copied from a website into NP++ the cursor position is messed up. It is not between the characters, but e.g. above a character. See attached screenshot. As far as I can see, this happens only when copying text from a website.
        Ekopalypse @Alter Graubart
        @Alter-Graubart
        can you post the debug info which is available from the last menu item, the ? menu?
          Alter Graubart
          Notepad++ v7.9 (64-bit)
          Build time : Sep 22 2020 - 03:19:04
          Admin mode : ON
          OS Version : 2004
          OS Build : 19041.572
          Current ANSI codepage : 1252
          Plugins : ComparePlugin.dll mimeTools.dll NppConverter.dll NppExport.dll
            Alter Graubart
            I just found the solution: I had the idea that it might got something to do with my 4k monitor and upscaling and indeed this is the solution: With standard settings, the menu items and icons in NP++ are very small on a 4k monitor. To avoid this and blurry menus I changed the high DPI settings to “System(Extended)”. Going back to default settings solved the problem.
            So maybe in a future update you can take the usage of NP++ on 4k monitor into account.
                @Alter-Graubart
                Afaik a newer scintilla release >= 4.4 is needed.
                DonHo, the author of npp mentioned that he wants to update scintilla in one of the next releases.
                  Alter Graubart
                  Just to give yo an impression of what I mean:
                  Standard settings:
                  changed High DPI settings:
                  EkopalypseE Alan KilbornA 2 Replies Last reply Reply Quote 0
                    @Alter-Graubart
                    I’m not 100% sure but it could be that this issue is covered by that
                    conversation/patch. This patch has been introduced in scintilla 4.4
                      Alan Kilborn @Alter Graubart
                      @Alter-Graubart
                      I don’t see a difference in those two screenshots.
                      EkopalypseE Alter GraubartA 2 Replies Last reply Reply Quote 0
                        Ekopalypse @Alan Kilborn
                        take a closer look at the space sign - hard to see.
                          Alan Kilborn @Ekopalypse
                          @Ekopalypse
                          What is a “space sign”?
                          Really, I’m confused here.
                          The amount of horizontal spacing?
                          This thread started out talking about a caret/cursor.
                          I see one in neither of the screenshots.
                            Ekopalypse
                            @Alan-Kilborn said in Problem with cursor position:
                            @Ekopalypse
                            The sign used to visually represent a space char.
                            In the first screenshot there is one, but, yes, the 2nd and third do not contain any but from the discussion I thought it is clear that the problem is about the visual representation if using high dpi monitors.
                              Hmmm, I see visual whitespace in both screenshots.
                              I guess things can look different on different monitor types, but different is “okay” I suppose, if there is no usability problem, which I have yet to see evidence of from this discussion.
                              Hopefully if someone reports a bug they do a better job of describing it than is taking place in this discussion.
                              I’m not adding anything to this convo, so I’m out. :-)
                                Terry R
                                Sorry I can’t help but when I enlarged the High DPI screenshot I see this:
                                The “visual space” characters (aka red period) are sliding along the lines from their intended position… As being different from the standard monitor screenshot the High DPI seems the cause of the issue. Hopefully a solution will be in hand sooner rather than later.
                                  Alter Graubart @Alan Kilborn
                                  @Alan-Kilborn Look at the icon bar and you will see the difference. ;)
                                    icon bar
                                    Yes, different but “usable”?
                                    The toolbar icons for one of the plugins, on the far right, are much smaller in one case.
                                    More disturbing is what @Terry-R pointed out with the whitespacing dots.
                                    It’s probably just a “legacy app” issue that isn’t going to get fixed soon, if ever.
                                    But thanks to all who pointed specifically what is different in the images. It would have been great to have a short textual list with the first posting of the screenshots, to save anyone who cared the time spent doing “Where’s Waldo”.
