    Perl subroutine calltips - with PythonScript
    52 Posts 4 Posters 17.8k Views 2 Watching
      Ekopalypse
      Ok, I should have installed strawberry perl in first place, solved all my issues.
      First success
      from ctypes import CDLL, POINTER, c_int, c_char_p
      perllib = CDLL(r'D:\strawberry\perl\bin\perl532.dll')
      perllib.RunPerl.restype = c_int
      perllib.RunPerl.argtypes = c_int, POINTER(c_char_p), POINTER(c_char_p)
      __args = [b"",
                b"-le",
                b"use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();"]
      args = (c_char_p * len(__args))(*__args)
      x = perllib.RunPerl(len(args), args, None)
      print(x)
      This works, but only one time. A second call results in a
      OSError: exception: access violation writing 0x0000000000000024
      Seems some cleanup needs to be done afterwards.
      Michael VincentM PeterJonesP 2 Replies Last reply Reply Quote 2
      • Michael VincentM Offline
        Michael Vincent @Ekopalypse
        @Ekopalypse said in Perl subroutine calltips - with PythonScript:
        Yes, in my late night Google-ing I saw lots of references to free(args) after the RunPerl() call.
        Examples:
        https://comp.lang.perl.misc.narkive.com/r7M6eENL/dll-unload-question-for-embedded-perl-on-windows
        https://www.nntp.perl.org/group/perl.wxperl.users/2017/01/msg9715.html
        Cheers.
          PeterJones @Ekopalypse
          __args = [b"", …
          Weird. If I don’t have the empty zeroth argument, the call fails (x==9). I wonder why it needs the blank argument…
          Michael VincentM 1 Reply Last reply Reply Quote 2
            Michael Vincent @PeterJones
            @PeterJones said in Perl subroutine calltips - with PythonScript:
            I read some stuff on Par::Packer and it seems the first argument may be the optional path to the perl executable.
            https://oliverbetz.de/pages/Artikel/Portable-Perl-Applications
            Cheers.
              Ekopalypse
              Hmm … it looks like freeing the interpreter is the issue.
              I tried to replicate what RunPerl is doing and when I use this
              from ctypes import CDLL, POINTER, c_int, c_char_p, c_void_p, byref
              # perllib.RunPerl.restype = c_int
              # perllib.RunPerl.argtypes = [c_int, POINTER(c_char_p), POINTER(c_char_p)]
              # Perl_sys_init3(int* argc, char*** argv, char*** env)
              perllib.Perl_sys_init3.argtypes = [POINTER(c_int), POINTER(POINTER(c_char_p)), POINTER(POINTER(c_char_p))]
              # PerlInterpreter * perl_alloc(void)
              perllib.perl_alloc.restype = c_void_p
              perllib.perl_alloc.argtypes = []
              # void perl_construct(pTHXx)
              perllib.perl_construct.argtypes = [c_void_p]
              # int perl_parse(pTHXx_ XSINIT_t xsinit, int argc, char **argv, char **env)  # only 4 params ??
              perllib.perl_parse.restype = c_int
              perllib.perl_parse.argtypes = [c_void_p, c_void_p, c_int, POINTER(c_char_p), POINTER(c_char_p)]  # we need 5 params according to RunPerl
              # int perl_run(pTHXx)
              perllib.perl_run.restype = c_int
              perllib.perl_run.argtypes = [c_void_p]
              __args = [b"", b"D:\\scripts\\perl\\1.pl" ]
              # ********************************  content of 1.pl  ********************************
              # use strict;
              # use warnings;
              # my $timestamp = localtime(time);
              # sub logit {
              	# my $message = shift;
              	# my $filename = 'D:/report.txt';
              	# open(my $fh, '>>', $filename) or die "Could not open file '$filename' $!";
              	# print $fh $timestamp, " $message\n";
              	# close $fh;
              # logit("test");
              perllib.Perl_sys_init3(byref(c_int(len(args))), None, None)
              my_perl = perllib.perl_alloc()
              perllib.perl_construct(my_perl)
              result = perllib.perl_parse(my_perl, None, len(args), args, None)
              print('perl_parse', result)
              result = perllib.perl_run(my_perl)
              print('perl_run', result)
              print(open(r'D:\report.txt', 'r').read())
              I can run 1.pl multiple times
                Ekopalypse
                I guess I have a working “embedded” perl instance.
                # int perl_destruct(pTHXx)
                perllib.perl_destruct.restype = c_int
                perllib.perl_destruct.argtypes = [c_void_p]
                # SV* Perl_eval_pv(pTHX_ const char *p, I32 croak_on_error)
                perllib.Perl_eval_pv.restype = c_void_p
                perllib.Perl_eval_pv.argtypes = [c_void_p, c_char_p, c_int]
                # # SV * Perl_sv_pv(pTHX_ const IV i)
                perllib.Perl_sv_pv.restype = c_char_p
                perllib.Perl_sv_pv.argtypes = [c_void_p, c_void_p]
                __args = [b"", b"-e", b"0"]  # test_npp
                if perllib.perl_parse(my_perl, None, len(args), args, None) == 0:
                    for perlcode in [b"reverse 'rekcaH lreP rehtonA tsuJ'", b"$a = 3; $a **= 2", b"$a = 3; $a **= "]:
                        val = perllib.Perl_eval_pv(my_perl, c_char_p(perlcode), 0)
                        print(perllib.Perl_sv_pv(my_perl, val))
                else:
                    print('Perl interpreter setup error.')
                print(perllib.perl_destruct(my_perl))
                Next step would be to identify errors (see last example code)
                and make additional modules working. I assume this has something
                to do with the @INC …
                and of course make a class out of it for easy reuse.
                  Ekopalypse
                  I guess I have a working solution.
                  I’m afraid, it works, currently, only with PythonScript version 3.x
                  There is one open point, see TODO, which I can’t seem to find a solution for.
                  from ctypes import CDLL, POINTER, c_int, c_char_p, c_void_p, byref, CFUNCTYPE
                  from Npp import console
                  Perl_sys_init3 = perllib.Perl_sys_init3
                  perl_alloc = perllib.perl_alloc
                  perl_construct = perllib.perl_construct
                  # int perl_parse(pTHXx_ XSINIT_t xsinit, int argc, char **argv, char **env)  # only 4 params but pTHXx_ is a macro resulting in 5 params
                  xsinit = CFUNCTYPE(None, c_void_p)
                  perl_parse = perllib.perl_parse
                  perl_parse.argtypes = [c_void_p, xsinit, c_int, POINTER(c_char_p), POINTER(c_char_p)]
                  perl_run = perllib.perl_run
                  perl_destruct = perllib.perl_destruct
                  Perl_eval_pv = perllib.Perl_eval_pv
                  Perl_sv_pv = perllib.Perl_sv_pv
                  # SV * Perl_sv_string_from_errnum(pTHX_ int errnum, SV *tgtsv)
                  Perl_sv_string_from_errnum = perllib.Perl_sv_string_from_errnum
                  Perl_sv_string_from_errnum.restype = c_void_p
                  Perl_sv_string_from_errnum.argtypes = [c_void_p, c_int, c_void_p]
                  # SV* Perl_get_sv(pTHX_ const char *name, I32 flags)
                  Perl_get_sv = perllib.Perl_get_sv
                  Perl_get_sv.restype = c_void_p
                  Perl_get_sv.argtypes = [c_void_p, c_char_p, c_int]
                  # void boot_DynaLoader (pTHX_ CV* cv)
                  boot_DynaLoader = perllib.boot_DynaLoader
                  boot_DynaLoader.argtypes = [c_void_p, c_char_p]
                  # Perl_newXS(pTHX_ const char *name, XSUBADDR_t subaddr, const char *filename)
                  Perl_newXS = perllib.Perl_newXS
                  Perl_newXS.argtypes = [c_void_p, c_char_p, c_void_p, c_char_p]
                  class PerlInterpreter:
                      def __init__(self):
                          Perl_sys_init3(byref(c_int(3)), None, None)
                      @staticmethod
                      def call(perlcode):
                          # TODO: https://perldoc.perl.org/perlembed#Maintaining-a-persistent-interpreter
                          # PL_exit_flags |= 0x2  # PERL_EXIT_DESTRUCT_END
                          # I assume, that this would avoid calling alloc, construct and parse over and over again.
                          # but how can we set it, seems not to be exported.
                          # Following code fails: ValueError: symbol 'PL_exit_flags' not found
                          # exit_flags = c_int.in_dll(perllib, 'PL_exit_flags')
                          # exit_flags.value |= 2
                          my_perl = perl_alloc()
                          def xs_init(pTHX):
                              # https://perldoc.perl.org/perlembed#Using-Perl-modules,-which-themselves-use-C-libraries,-from-your-C-program
                              Perl_newXS(pTHX,
                                         b"DynaLoader::boot_DynaLoader",
                                         boot_DynaLoader,
                                         b'__FILE__' # Seems to work, but ... ??
                          res = perl_parse(my_perl, xsinit(xs_init), 3, (c_char_p * 3)(*[b"", b"-e", b"0"]), None)
                          if res != 0:
                              _error = Perl_sv_pv(my_perl,
                                                  Perl_sv_string_from_errnum(my_perl, res, None))
                              raise(RuntimeError(f'Perl interpreter setup error. {_error.decode()}'))
                          result = Perl_sv_pv(my_perl,
                                              Perl_eval_pv(my_perl, c_char_p(perlcode.encode()), 0))
                          error = Perl_sv_pv(my_perl, Perl_get_sv(my_perl, "@".encode(), 0)).decode()
                          return error, result.decode()
                  if __name__ == '__main__':
                      perl = PerlInterpreter()
                      for perlcode in [
                                       "use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();",
                                       "$a = 3; $a **= 2",
                                       "$a = 3; $a **= ",
                          error, result = perl.call(perlcode)
                          if error:
                              console.writeError(error+'\n')
                          else:
                              print(result)
                    And maybe “newer” Perl as well. I’m on Strawberry 5.24 and get this:
                      File "C:\usr\bin\npp64\plugins\PythonScript\scripts\EmbeddedPerl.py", line 46, in <module>
                      File "C:\usr\bin\npp64\plugins\PythonScript\lib\ctypes\__init__.py", line 386, in __getattr__
                        func = self.__getitem__(name)
                      File "C:\usr\bin\npp64\plugins\PythonScript\lib\ctypes\__init__.py", line 391, in __getitem__
                        func = self._FuncPtr((name_or_ordinal, self))
                    AttributeError: function 'Perl_sv_string_from_errnum' not found
                    I don’t want to sound ungrateful - what you’ve done is amazing, just thought you should know.
                    Cheers.
                    EkopalypseE 2 Replies Last reply Reply Quote 0
                      Ekopalypse @Michael Vincent
                      @Michael-Vincent
                      Thx for testing. I think I’m using the newer version, mine is called 5.32.
                      Any thoughts on what a reasonable version to start with might be?
                        @Michael-Vincent
                        according to git this api function was introduced in 2017
                        658db62260a (Zefram                   2017-08-13 01:59:43 +0100  689) #define sv_string_from_errnum(a,b)        Perl_sv_string_from_errnum(aTHX_ a,b)
                        but 5.24 has been released on May 8, 2016
                          Ekopalypse
                          Just to make clear, this function is not really needed.
                          It just provides a textual description of an error number.
                          One can comment
                                      # _error = Perl_sv_pv(my_perl,
                                      #                    Perl_sv_string_from_errnum(my_perl, res, None))
                          and change the runtime raise to
                          raise(RuntimeError(f'Perl interpreter setup error. {res}'))
                          and it should work. Hopefully.
                            That worked!
