    Using Zen coding on updated notepad++
    2 Posts 2 Posters 2.1k Views 1 Watching
    • Tusar TarunT Offline
      Tusar Tarun
      How do i can use zen coding with my updated notepad++. when i am updating notepad++ my zen coding doesn’t working. and has their any dark mood option on notepad++ ???
        PeterJones @Tusar Tarun
        @Tusar-Tarun ,
        You didn’t mention what version you upgraded from, or what version you upgraded to. If the “from” was old enough, the plugin would have to move.
        Other things to look at:
        • https://community.notepad-plus-plus.org/topic/19118/zen-coding-plugin-installed-but-not-working
        • https://community.notepad-plus-plus.org/topic/18916/zen-coding-plugin-problem-solved
        If you want more than that, you’re going to have to provide more detail.
        dark [mode]
        Probably not to your definition. There are plenty of dark themes in the Settings > Style Configurator > Select Theme pulldown options. But that doesn’t change the UI itself to use a “dark mode”. You can search the forum for plenty of other topics about this… it might be possible to configure Windows to be dark, and the Notepad++ UI will inherit that darkness. But that’s really not a Notepad++ -specific question (though the linked search will provide some insight into the process)
