    Strange characters while using column select
    3 Posts 2 Posters 557 Views 1 Watching
    • Pierre van der VenP Offline
      Pierre van der Ven
      Sometimes it happens that I get strange characters when trying to ie replace the first three characters of all lines by using column select. I hit SHIFT+ALT, when I release them I get the characters (check screenshots). The characters differ.
      What can cause this? It does not happen all the time.
      2021-01-05 08_12_45-_new 14 - Notepad++.png 2021-01-05 08_13_15-_new 14 - Notepad++.png
        Alan Kilborn @Pierre van der Ven
        @Pierre-van-der-Ven
        Are you using the arrow keys on the numeric keypad to move the caret to define your column block?
        If so, there is a known issue with doing this; see https://github.com/notepad-plus-plus/notepad-plus-plus/issues/5321
        It appears to be a Scintilla bug (but fixed there) so it will not be fixed until Notepad++ updates the version of Scintilla it uses, which happens very infrequently.
        Pierre van der VenP 1 Reply Last reply Reply Quote 3
          Pierre van der Ven @Alan Kilborn
          @Alan-Kilborn That looks exactly like my issue. Thanks!
