    How to get correct syntax highlighting for Python 3 formatted strings
    9 Posts 4 Posters 1.9k Views 2 Watching
    • J VickroyJ Offline
      J Vickroy
      For me, Notepad++ 7.9.1 is rendering f-strings as unstyled text rather than in the style of regular strings.
      Could someone provide guidance on how to address this issue?
      Thanks.
      /jimv
        Alan Kilborn @J Vickroy
        @J-Vickroy
        Have you tried searching this forum for f-strings ?
          J Vickroy
          Thanks for your quick response.
          I did search this forum prior to posting - implicit in my subject title being verbatim that of a previous (now locked) posting.
          My search revealed posts on this subject by you (among others) that seemed to indicate f-string styling should be supported by Notepad 3.9.1 without modification to XML configuration files. Am I mistaken?
          Prior to posting, I also verified C:\Program Files (x86)\Notepad++\stylers.model.xml contains F STRING specifications under the <LexerType name=“python” desc=“Python” ext=“”> tag.
          I’m misunderstanding something, but I do not know what.
          Michael VincentM PeterJonesP 2 Replies Last reply Reply Quote 0
          • Michael VincentM Online
            Michael Vincent @J Vickroy
            @J-Vickroy said in How to get correct syntax highlighting for Python 3 formatted strings:
            You’re using the default styler, not a theme, correct?
            J VickroyJ 1 Reply Last reply Reply Quote 1
              PeterJones @J Vickroy
              Right. but does your %AppData%\Notepad++\stylers.xml (or, appropriate theme) also contain the F STRING. Because stylers.model.xml is only read if there isn’t a stylers.xml in an appropriate config directory (either the install directory or the appdata location I mentioned or in your cloud folder) – and that, only to effectively copy stylers.model.xml right\path\to\stylers.xml before loading that new stylers.xml. If you have an outdated stylers.xml (or if you have a different theme selected, and the theme config XML hasn’t been updated), then the config file Notepad++ actually reads that stylers.xml (or theme xml), and doesn’t see the F STRING setting.
              Hmm, I haven’t found that verbatim-title post yet. My search-fu must be weak.
              I did find Python Syntax Highlighting, whose last post gives the strong indication that having an outdated theme can be the culprit.
              Or then there’s the Python 3 f-strings not colourizing correctly discussion, where the user supplied the screenshot showing that the Style Configurator was out of date – where I even provide a procedure for how to copy the relevant portions of stylers.model.xml into stylers.xml, if you don’t want to overwrite any other customizations you’ve made to stylers.xml.
                J Vickroy @Michael Vincent
                @Michael-Vincent
                Thanks for your reply. I was using the Zenburn theme, but switching to Default (stylers.xml) did not alter the behavior.
                  … which confirms that your stylers.xml has not been updated to match stylers.model.xml. (and I just checked: the most recent zenburn.xml has not been updated to have f-string syntax…)
                  So follow the instructions I linked which explain how to get those appropriate lines from stylers.model.xml into stylers.xml or zenburn.xml, or whatever theme you want to put them in (same instructions, different filename).
                    J Vickroy @PeterJones
                    Thanks Peter.
                    I just verified my %AppData%\Notepad++\stylers.xml file did not contain any F * entries.
                    Adding the F * entries to stylers.xml and switching to the Default theme fixed the issue. So it seems, I did have to modify an XML (stylers.xml) file.
                    All that remains is for me to determine how to make it work for other (e.g., Zenburn) themes.
                      Thanks again Peter for your followup post with the link on how to repair for non-default themes! This is great and I learned something in the process!
