    Macro problem (replace text)
    6 Posts 4 Posters 943 Views 3 Watching
    • Юрий МарковЮ Offline
      Юрий Марков
      Recently updated to the latest version. I have a macro that replaces the text T_ with “empty”. Now, every time I use it, the prompt “are you sure you want to replace?” and this window does not even use the dark theme for which I was updating. How can I remove this request? I want him to immediately replace the text as it was before.
      Neil SchipperN PeterJonesP 2 Replies Last reply Reply Quote 0
      • Neil SchipperN Offline
        Neil Schipper @Юрий Марков
        @Юрий-Марков Have you tried recreating the macro? This would at least discriminate between ‘undesired interpretation of old macro’ vs. ‘inability for text replace macro to run without confirmation’, which is a different type of anomaly.
          PeterJones @Юрий Марков
          @Юрий-Марков ,
          You might want to check the settings in Settings > Preferences > Searching, especially the state of “Confirm Replace All in All Opened Documents” (as documented in the online user manual).
          If I switch to Русский :
          With that option on, and try to do a replace-all-in-all-opened-documents – I don’t read Русский, but it looks like I get the same message you do:
          whereas if I turn off that option, it doesn’t ask, and just does the replacement.
          So turn off that option, and your macro will go back to working.
          Юрий МарковЮ 1 Reply Last reply Reply Quote 3
            Юрий Марков @PeterJones
            @PeterJones Thank you very much, apparently some new setting has appeared, and this request does not appear if you use the replacement window, not a macro.
              Alan Kilborn @Юрий Марков
              @Юрий-Марков said in Macro problem (replace text):
              Software is continually being enhanced
              Incorrect, it appears either way, any time you use Replace All in All Opened Documents (unless you change the Preference setting that was shown for it)
              Юрий МарковЮ 1 Reply Last reply Reply Quote 1
                Юрий Марков @Alan Kilborn
                @Alan-Kilborn said in Macro problem (replace text):
                It’s just that I haven’t updated Notepad ++ for a very long time))) Purely by chance I saw that a dark theme appeared, I have been dreaming about it for 3 years, everything has a dark theme for a long time, even in Total Commander it appeared.
