    need help with xml plugin
    8 Posts 2 Posters 4.0k Views 1 Watching
    • Mike NiehorsterM Offline
      Mike Niehorster
      I get an access violation error everytime i try to validate a file
      • Michael VincentM Offline
        Michael Vincent @Mike Niehorster
        @mike-niehorster
        Upgrade to the latest version.
        Mike NiehorsterM 1 Reply Last reply Reply Quote 0
          Mike Niehorster @Michael Vincent
          @michael-vincent i have and I’ve reinstalled the plugins as well
            @mike-niehorster said in need help with xml plugin:
            Upgrade to the latest XML Tools plugin.
              @michael-vincent thank you. i made sure i had that and im still getting the same thing. fyi im totally new at all of this, is there something i can be overlooking? like format or setting or anything?
              Mike NiehorsterM Michael VincentM 2 Replies Last reply Reply Quote 0
                Mike Niehorster @Mike Niehorster
                @mike-niehorster the error says "pluginsmanager::runplugincommand access violation
                  Report your bug on the XML Tools plugins issue page. Please be sure to include DETAILED information, like:
                  • Notepad++ Debug info (from the menu ?=>Debug Info…)
                  • Your XML Tools version
                  • The XML file your trying to validate
                  • The XML schema you’re using,
                  • any other information that will make it easy for the developers to reproduce you bug. If it can’t be reproduced, it won’t be fixed.
                  Cheers.
                  Michael VincentM 1 Reply Last reply Reply Quote 4
                    Michael Vincent @Michael Vincent
                    @michael-vincent said in need help with xml plugin:
                    Done - https://github.com/morbac/xmltools/issues/148
                    Cheers.
