    EOL Code Removal in Double Quote
    2 Posts 1 Posters 598 Views 1 Watching
    • Kenneth YuK Offline
      Kenneth Yu
      I have a csv using , as delimiter and " as quote and \n as line breaker.
      Some records has a line breaker code \n in a text field and Notepad++, Excel, PowerBI parse it as new record, corrupting the table.
      Since the line breaker code in the text field is same as the code to break for new record I have trouble replacing the wrong line breaker.
      I have used regex to find ^“(.)[\r\n](.*)”$ then replace “$1 $2”, while it works for the records with error it also removed line breakers of clean row.
      I wonder if there’s another way I can try to correct the CSV file.
      Thanks.
      Kenneth YuK 1 Reply Last reply Reply Quote 0
        Kenneth Yu @Kenneth Yu
        @Kenneth-Yu
        Problem solved, I eventually found out that the error comes in \r\r\n, replaced them and all is good.
