    Updater doesn't work, need proxy address?
    1 Posts 1 Posters 1.3k Views 1 Watching
    • Jonathan ColesJ Offline
      Jonathan Coles
      After a fresh install, ? > Update Notepad++ responds with a “curl error” dialog saying, “Failed to connect to 0.0.0.0 port 1080 after 0ms: Address not available.”
      Update used to work with the default proxy settings of 0.0.0.0 and port 0. These defaults are still listed in ? > Set Updater Proxy and in GUP.xml. But the curl error message still reports the error on port 1080. It looks like the port setting is being ignored.
      Debug info:
      Notepad++ v8.5 (64-bit)
      Build time : Mar 6 2023 - 02:18:13
      Command Line :
      Cloud Config : OFF
      OS Version : 22H2
      OS Build : 19045.2728
      Current ANSI codepage : 1252
      Plugins :
      mimeTools (2.9)
      NppConverter (4.5)
