    Shift+F3 no more works
    15 Posts 7 Posters 3.4k Views 2 Watching
    • R Offline
      reinhardhofmann
      It seems that since a recent update, Shift+F3 does no more backwards-search, while F3 and Ctrl+Shift+F3 still work, and no conflict is shown in the shortcuts settings. Howto reenable it?
        Hello, @reinhardhofmann and All,
        • Close any Notepad++ instance
        • Open your active config.xml file with Microsoft notepad ( not Notepad++ )
        • Move near the end of the third line, beginning with FindHistory nbMaxFindHistoryPath...
        • You should see an attribute named regexBackward4PowerUser="no"
        • Change its value from no to yes
        • Save the changes
        • Close Microsoft notepad
        • Open Notepad++
        => From now on, the backward regex search will be available ;-))
          Alan Kilborn @guy038
          @guy038 said in Shift+F3 no more works:
          @reinhardhofmann But don’t report any bugs regarding behavior that seems unusual when you are searching in a backwards direction with regular expressions – that’s why this feature is sort of hidden – too keep people from noticing and reporting unexpected behavior.
          • mkupperM Offline
            mkupper @reinhardhofmann
            @reinhardhofmann Your observed behavior is “normal behavior” for Notepad++. There is a “gotcha” with it.
            If you bring up the finder window (Ctrl-F) the Search Mode choices in the lower-left corner are Normal, Extended, and Regular expression. Shift F3 works if you are in Normal or Extended mode. Shift-F3 does not work if you are in Regular expression mode.
            @guy038 gave you a “back door” thing that enables Shift-F3 when in Regular expression mode. It’s in the Notepad++ manual and so it’s not like it’s a super-secret thing… :-)
            @Alan-Kilborn warns that there may be unusual behavior when doing a backwards regular expression search using shift-F3. The manual warns you about “sometimes surprising results” but other than that, it’s best to dial up your favorite mysterious music when attempting to discover edge conditions of what happens if you perform regular expressions, backwards.
              Alan Kilborn @mkupper
              @mkupper said in Shift+F3 no more works:
              @PeterJones Maybe the user manual should provide an example?
                PeterJones @Alan Kilborn
                @Alan-Kilborn said in Shift+F3 no more works:
                If someone were to create an issue in the UM repo, and provide an example regex that will not work as expected in backwards mode, I could add it into the manual. (But I don’t know how to craft a simple regex that would have an obvious meaning when searching forward, but mess up when searching backward, so I cannot come up with an example myself.)
                  Alan Kilborn @PeterJones
                  It seems like there should be one when that “power user” mode thing was added to Notepad++. I’ll see if I can find it.
                    Hi, @reinhardhofmann, @alan-kilborn, @mkupper and All,
                    Hi, All, do you know that, even with the regexBackward4PowerUser enabled, there are still some cases where the backward regex search do not work ?
                    For example, in a new tab, copy this text :
                    This is à test
                    This is à second test
                    This is à third test
                    This is à final test
                    Note that, in each line, I replaced the indefinite English article a with the French accentuated letter à !
                    • Move to the beginning of this file
                    • Select the à letter, in line 1
                    • Open the search dialog ( Ctrl + F )
                    • Tick the Wrap around box option
                    • Hit on the Find Next button
                    => The à char, in line 2, should be selected
                    • Close the Find dilaog ( Esc )
                    • Hit the F3 key
                    => Again, the à char, in line 3, should be selected
                    • Now, use the Shift+ F3 shortcut => Nothing happened ???
                    ( Of course, I suppose that you do have the string regexBackward4PowerUser="yes", in your active config.xml file ! )
                    This happens ONLY IF :
                    • Your search mode is Regular expression
                    • The searched character is over \x{007F}
                    • The current encoding file is an Unicode one : UTF-8, UTF-8-BOM, UTF-16 BE BOM or UTF-16 lE BOM
                    Luckily, I’ve found a way around this limitation. The rule is :
                    When a backward regex do not work as expected, simply add the regex string (?=(?s).) at the end of the present regex !
                    Thus, if we, now, search for the regex à(?=(?s).), you should be able to search backwards or forwards, at any time !
                      Hello, @peterjones, and All,
                      Regarding examples to include in the Official documentation, here are two examples which :
                      • Do not work at all, in backward direction, if the regexBackward4PowerUser is not set
                      • Else, allows the regex backward search but gives right results in the first example only
                      Let’s consider the following text, where I included, this time, the classical English a article :
                      This is a test
                      This is a second test
                      This is a third test
                      This is a final test
                      • If the regexBackward4PowerUser option is enabled ( "yes" ) :
                        • The regex (?-s)i.*te does find the greatest range of characters, between a i letter and the te string in BOTH forward AND backward search
                        • The regex (?s)i.+ does find the greatest range of chars, beginning with an i letter, in forward search BUT finds multiple wrong occurrences when used in backward direction !
                      • If the regexBackward4PowerUser option is disabled ( "no" ) :
                        • The two regexes works as expected in forward direction and CANNOT be used in backward direction
                      BR
                        @guy038
                        YES! No one ever said all regexes work fine moving backward in this mode. If they did, there’d be no need for the mode to exist at all!
                          What about (?s)i.+(?=.) for this case?
                          (I’m away from my Notepad++ PC right now so I can’t try it)
                          • Mark OlsonM Offline
                            Mark Olson
                            Nobody has talked about trying to actually solve the issues with backward regex searching, but it seems to me like a potential solution might be along these lines:
                            when someone regex-searches backwards:
                                if need-to-re-search-file:
                                    regex-search the entire file starting from the beginning
                                find the last match before the current position
                            when someone edits a file or changes the regex to be searched:
                                set need-to-re-search-file = true
                            Obviously I’m not saying this would be easy and I fully expect it would be very hard to implement, but what do people think about that idea?
                              Coises @Mark Olson
                              @Mark-Olson said in Shift+F3 no more works:
                              Perhaps I have missed it, but I have not yet seen the issues precisely defined. In particular, I haven’t seen it stated whether the problem is that:
                              1. the expected result of backward searching with a regular expression is not always well-defined.
                              2. the expected result is well-defined, but the implementation — due to Boost, Scintilla, Notepad++ or some combination thereof — is not always correct.
                              Is it known which applies, and under what specific conditions?
                              CoisesC 1 Reply Last reply Reply Quote 2
                                Hello, @reinhardhofmann, @mkupper, @alan-kilborn, @peterjones, @mark-olson, @coises and All,
                                Oh…, in my previous post, I did a mistake : I spoke about a second example (?s)i.+. But, I really did tests with the regex (?-s)i.+ !
                                When the backward regex search is allowed, EACH backward regex (?-s)i.+ finds a string, reduced by a single character
                                But, unfortunately, Alan, the regex (?-s)i.+(?=(?s).) do not give the expected results, allthough it reduces the number of steps before a CORRECT backward occurrence !
                                Thus, my general rule should be modified as :
                                When a backward regex do not work as expected, try adding the regex string (?=(?s).) at the end of the present regex. It may work correctly !
                                  Coises @Coises
                                  I wrote in Shift+F3 no more works that the problem might be:
                                  Example of how this could be ambiguous:
                                  Given the text:
                                  xabcdefy
                                  and the regular expression:
                                  (a..(d..)?|.e)
                                  when matching normally there is one match — abcdef. When matching backward, is there one match — abcdef — or are there two matches — de and abc?
                                  What about the regular expression:
                                  (a..(d.)?|.f)
                                  matching backward: abcde or ef and abc?
