    Multi-edit
    8 Posts 4 Posters 5.1k Views 2 Watching
    • Alan ChanA Offline
      Alan Chan
      Sorry if I missed how to use this functionality.
      For instance (using the example), if I double-click “obj” they get highlighted but what I do next? Say if I wanted to add “ject” to change to “object”?
      It didn’t seem obvious looking at the GIF how to multi-carat edit. In the version I downloaded I cannot see the option in the Settings > Preferences > Editing > ☑ Enable Multi-Editing (Ctrl+Mouse click/selection) checkbox.
      Alan KilbornA PeterJonesP 2 Replies Last reply Reply Quote 1
        Alan Kilborn @Alan Chan
        @Alan-Chan said in Multi-edit:
        That’s because is isn’t obvious.
        There probably needs to be a tutorial; the GIF alone isn’t worth much without telling people how it is done.
        That checkbox has disappeared because multi-editing is enabled always as of N++ 8.6.
        Alan ChanA 1 Reply Last reply Reply Quote 0
          Alan Chan @Alan Kilborn
          Thanks for confirming that it’s always enabled.
          Now, where do I find how to use it? (in particular the 2nd example) rather than the column edit which I figured out.
          Alan KilbornA 2 Replies Last reply Reply Quote 0
            Barring someone creating a tutorial (which I’m not going to do because I’m not much interested in the multi-editing stuff), you might have a look at the supported new commands involving it, and experimenting with them:
              PeterJones @Alan Chan
              For the specific circumstance you described, without creating a whole tutorial
              1. Double-click a whole word instance of obj
              2. Use the Edit > Multi-Select All submenu as @Alan-Kilborn suggested
                • Match Whole Word Only would match any instance of obj or Obj, but not subobj or objuice
                • Match Case & Whole Word would match any instance of obj, but not Obj or subobj or objuice
                • this will fully select all the matches
              3. At this point, you could “type over” by just typing object, and all the selected instances will be changed.
              The User Manual will soon have brief descriptions of those new Edit-menu submenus, but that’s usually not triggered until “auto-update” is triggered – my guess is that will be happening in the near future.
                @Alan-Chan
                BTW, the real-world way to use these menu commands is to tie keyboard shortcuts to the ones you’ll use with regularity. No one would actually use these commands from the menus.
                Michael VincentM PeterJonesP 2 Replies Last reply Reply Quote 2
                • Michael VincentM Offline
                  Michael Vincent @Alan Kilborn
                  @Alan-Kilborn said in Multi-edit:
                  @Alan-Chan
                  For example, I use:
                  Multi-select ALL => Match Case & Whole Word : Ctrl+Shift+.
                  Multi-select Next => Match Case & Whole Word : Ctrl+.
                  Undo the Latest Added Multi-Select : Ctrl+,
                  Skip Current & Go to Next Multi-select : Ctrl+Alt+.
                  The , and . because those keys also have the < and > respectively so Ctrl+. is like selecting the current word and subsequent Ctrl+. keystrokes select the next (forward in the document - as in an “arrow” to the right >) match. The Alt modifier skips the current one and the Shift modifier selects all.
                  And of course when doing this, I’m 99% always expecting to match the exact word; hence, “Match Case & Whole Word”.
                  Cheers.
                  PS: Should also note that I had these exact keystrokes mapped to the NppExec scripts I had that did this exact functionality before it became “native” to N++, so they are muscle memory at this point as I’ve been multi-editing this way for years now.
                    PeterJones @Alan Kilborn
                    I cannot remember any more keystrokes, so I’m not likely to assign a keyboard shortcut. Instead, if I find myself wanting to use the new features, I’ll probably add them to the contextMenu.xml, so they’re just a local right-click away.
                    … But yes, if I do end up using them often, it will need to be easier access than having to move my mouse cursor up to the main menu system.
