    please help me !
    3 Posts 2 Posters 707 Views 1 Watching
    • Hatim MelloukiH Offline
      Hatim Mellouki
      I want to search a very large number of text files at the same time, and they are large files +2 GB. When the search starts, I must press Yes every time to move from one file to another. Can I confirm with one click?
      Because there are a large number of files
        Coises @Hatim Mellouki
        @Hatim-Mellouki said in please help me !:
        It would probably be easier and faster to use a command line tool, like grep for Windows, for this kind of task.
        However, if you really want to use Notepad++, select Settings | Preferences… from the main menu, click Performance on the left side and then check Suppress warning when opening ≥ 2GB files.
        Hatim MelloukiH 1 Reply Last reply Reply Quote 2
          Hatim Mellouki @Coises
          @Coises thank you very much sir
