    Loss of ability to create two vertical lines in Vertical Edge Settings
    6 Posts 3 Posters 1.0k Views 1 Watching
    • FNActivityF Offline
      FNActivity
      Hello, I previously had the ability to draw two vertical lines in Vertical Edge Settings, which allowed me to write text in contained view mode. However, I can no longer do this. Before asking this question, I’ve read all similar questions, but none of them addressed my specific issue
      This issue represents a significant problem for my workflow in Notepad++
      Thank you
      • Lycan ThropeL Offline
        Lycan Thrope @FNActivity
        @FNActivity ,
        You don’t provide your ?->Debug info..., so we don’t know what version you’re using, nor do you show a screenshot of your actual editor behind that Settings dialog, so hard to see what color you use.
        That said, I’m able to do what you say, but setting a second vertical edge in my settings of 80 and 120. At best I suggest you show as my screenshot shows, both dialogs Preferences and Style Configurator along with the editor view so we can see the color choices you made. You may have a black screen with black edge, but we don’t know with what information that you haven’t given us. Check the Settings->Style Configurator...->Edge Color so we can see what your settings are, like this screenshot shows.
        FNActivityF 1 Reply Last reply Reply Quote 1
          FNActivity @Lycan Thrope
          @Lycan-Thrope
          I apologize for not knowing this information was needed
          I’ll definitely provide it :
          Debug info
          Notepad++ v8.7.5 (64-bit)
          Build time : Dec 21 2024 - 05:13:03
          Command Line :
          Cloud Config : OFF
          Periodic Backup : ON
          Placeholders : OFF
          DirectWrite : OFF
          Dark Mode : ON
          OS Version : 22H2
          OS Build : 19045.5247
          Current ANSI codepage : 1252
          Plugins :
          AutoSave (2)
          NppConverter (4.6)
          T 1 Reply Last reply Reply Quote 1
            Terry R @FNActivity
            @FNActivity
            If you were to select a dark mode (supplied with Notepad++, since your Material-Dark seems to be a custom one), say DarkModeDefault, do the vertical lines re-appear?
            If they re-appear that it’s seems likely your colour scheme isn’t setup correctly. As @Lycan-Thrope asked, what is your “Edge Color”? Play with the actual color used there for your custom dark theme as you may get the vertical lines to re-appear by swapping out your current color.
            FNActivityF 1 Reply Last reply Reply Quote 2
              FNActivity @Terry R
              @Terry-R
              Oh, I sincerely apologize for my unclear question. I can always see the two vertical lines (as shown in the previous image). I actually wanted to enable the Background mode option when both vertical lines are visible, which now that I think about it, doesn’t make much sense (at least for me). I’m sorry, I was completely distracted. Feel free to delete this thread if you’d like.
                Terry R @FNActivity
                @FNActivity said in Loss of ability to create two vertical lines in Vertical Edge Settings:
                Thanks for responding and letting us know. Yes, it was a bit of a wild goose chase. At least you appear to have answered your own question which isn’t the one in the title.
