    An issue with background color
    2 Posts 2 Posters 999 Views 2 Watching
    • sdfh6srtytydgf 65cghj67ed56u8S Offline
      As I am a complete novice user, this question may appear to be childish. Sorry !
      By editing two files ( root\themes\Obsidian.xml’ and ‘root\langs.xml’), I was able to customize the syntax highlighting for C language files and include user-defined keywords. I have most of my customizations set the background color to black, and now I want to change to black the background color of the entire document (except for the keywords that I have set differently) too.
      But ‘Settings > Style Configurator > Global override > Force background color for all style’ is not right for me because it resets to black everything, eliminating the background color of keywords where it is required to be a different color.
      I would appreciate it if you could suggest a solution or workaround. Thanks ! Kind Regards
        PeterJones @sdfh6srtytydgf 65cghj67ed56u8
        @sdfh6srtytydgf-65cghj67ed56u8 ,
        Settings > Style Configurator > Language: Global Style > Style: Default > Background sets the default bg color used by any style that doesn’t override the bg.
