    Help w/ console.run editor output
    3 Posts 2 Posters 1.1k Views 1 Watching
    • 4SHAKEN4 Offline
      4SHAKEN
      I’m trying to get output from an .exe call to return to the new editor window, but its only posting to the console window. Below is some “test” code to demonstrate the issue. Thanks for any help!
      from Npp import editor, notepad, console
      import time
      console.clear()
      console.show()
      notepad.new()
      time.sleep(0.3) # Delay 300ms to allow above cto complete
      console.run(r’C:\Software\dcmtk-3.6.9-win64-dynamic\bin\echoscu.exe -v -aet TEST -aec TEST123 127.0.0.1 105’, editor)
      console.run(r’cmd.exe /c “C:\Software\dcmtk-3.6.9-win64-dynamic\bin\echoscu.exe -v -aet TEST -aec TEST 127.0.0.1 105”‘, editor)
      console.run(r’cmd.exe /c ping localhost’, editor)
        Ekopalypse @4SHAKEN
        @4SHAKEN
        The editor object used in the console is the same class as the normal editor object.
        from Npp import console
        console.clear()
        print("hello")
        content = console.editor.getText()
        notepad.new()
        editor.setText(content)
        But if you are working with external programs, the subprocess module might be a better alternative
        4SHAKEN4 1 Reply Last reply Reply Quote 3
        • 4SHAKEN4 Offline
          4SHAKEN @Ekopalypse
          @Ekopalypse Great, that will suffice for what I’m trying to do. Thank you!
