    block comment color
    6 Posts 4 Posters 1.5k Views 2 Watching
    • Jim JulianJ Offline
      Jim Julian
      I find the color of block comment text (orang) on a white background, in python, makes reading difficult.
      I opened the style configurator but could find reference to only single line comment text color (green).
      Is there a way to change the color of python block comment text?
      Thanks.
      Alan KilbornA mpheathM 2 Replies Last reply Reply Quote 0
        Alan Kilborn @Jim Julian
        @Jim-Julian said in block comment color:
        As Python has no “block comment”, only “line comment”…I’m going to give you an answer of “No”.
        Jim JulianJ 1 Reply Last reply Reply Quote 0
          Jim Julian @Alan Kilborn
          @Alan-Kilborn That, I know, and yet, many if not most use single/double quotes to comment blocks of text.
          From Google AI:
          “It’s important to note that using triple-quoted strings as comments is generally discouraged by the
          Python community, especially when the commented code contains triple-quoted strings. The preferred method is to use consecutive single-line comments with #.”
          The column editor makes block commenting a lot easier, however, I just tried that and the text font changed for the commented text.
          How do I change that. The font is too small.
          Also, the combination of orange on white is hard too read but is used with Triple, Triple Double, F Triple, F Triple Double. What are they? I’d like to change those.
            PeterJones @Jim Julian
            The font for COMMENT LINE text is usually the same size and font-face as the Python language as a whole, and if it’s blank, it inherits the size and font-face from Style Configurator > Global Styles > Default Style. By default, the COMMENT LINE size and font-face are left blank, so either you are using a Theme which sets those (some themes foolishly set font faces and font sizes, rather than letting that get properly inherited from a user’s preference) or you changed them yourself at some point.
            Then change it.
            • TRIPLE = ''' text in triple single quotes'''
            • TRIPLE DOUBLE = """ text in triple double quotes"""
            • F TRIPLE = f'''formatted text with {varname} syntax in triple single quotes'''
            • F TRIPLE DOUBLE = f"""formatted text with {varname} syntax in triple double quotes"""
            Jim JulianJ 1 Reply Last reply Reply Quote 2
              Jim Julian @PeterJones
              @PeterJones Regarding the font issue: I use default settings to keep things simple. However, yoour suggestion is heard. Thanks for your assistance.
              • mpheathM Offline
                mpheath @Jim Julian
                Thanks.
                @PeterJones mentioned the (orange) triple strings. I’ll mention the (green) block comments.
                The lexer does style block comment text.
                https://github.com/notepad-plus-plus/notepad-plus-plus/blob/a679e8ebfb425ae4c71a34a2080dd1a9a376acd6/lexilla/lexers/LexPython.cxx#L908-L909
                Python has no multiline comment like C like languages unfortunely.
                 comment can span multiple lines
                The Python lexer does have block comments if that can be defined as such.
                # comment line
                ## old code
                ## old code
                The ## is SCE_P_COMMENTBLOCK style which in Style Configurator described as COMMENT BLOCK. It may not be noticeable as both SCE_P_COMMENTLINE and SCE_P_COMMENTBLOCK default to same style settings.
                Changed COMMENT BLOCK in Style Configurator to grey shows
                So now more customization can be done to improve the view.
