    Negative lookbehind regular expression not working on Notepad++
    43 Posts 6 Posters 35.4k Views 2 Watching
      Hello, @dr-ramaanand and All,
      Ah, I just having some spare time to answer your specific problem !
      As I said in a previous post, you cannot use look-behinds as they do NOT support variable quantifiers ! That’s why I proposed a method with the ((SKIP)(*F) feature, which works properly.
      In order to found out other methods, let’s begin with a simplified problem :
      Starting with this INPUT text :
      DEF  ABCDEF   ABC     DEF  ABCDEF   XYZDEF   ABCDEF
      The following regex S/R :
      FIND (?-is)ABCDEF(*SKIP)(*F)|DEF
      REPLACE 12345
      Matches only the DEF string when NOT preceded with the ABC string
      After the replacement, we get this OUTPUT :
      12345  ABCDEF   ABC     12345  ABCDEF   XYZ12345   ABCDEF
      • If DEF is preceded by ABC, NO replacement occurs
      • If DEF is NOT preceded by ABC it replaces the string DEF by the string 12345
      Now, using the same INPUT text :
      FIND (?-is)ABCDEF\K|(DEF)
      REPLACE ?{1}12345
      • Detect an empty match, when the DEF string is preceded by the ABC string
      • Detect some selected text, when the DEF string is NOT preceded by the ABC string
      But, due to the group, in the final part of the regex and due to the conditional replacement, it would produce this OUTPUT :
      As previously :
      • if DEF is preceded by ABC, NO replacement occurs
      • if DEF is NOT preceded by ABC it replaces the string DEF by the string 12345
      Let’s apply this new regex S/R to your problem. Thus, from this regex :
      FIND (?:<span\b[^>]*?color\s*:\s*black[^>]*>\s*|<p\b[^>]*?color\s*:\s*black[^>]*>\s*<span\b[^>]*>\s*)<code\s*style="background-color:\s*transparent;">(*SKIP)(*F)|<code\s*style="background-color:\s*transparent;">
      If we simply replace the (*SKIP)(*F) part by \K AND if we put all the right branch of the alternative within a group, this S/R becomes as :
      FIND (?:<span\b[^>]*?color\s*:\s*black[^>]*>\s*|<p\b[^>]*?color\s*:\s*black[^>]*>\s*<span\b[^>]*>\s*)<code\s*style="background-color:\s*transparent;">\K|(<code\s*style="background-color:\s*transparent;">)
      REPLACE ?1[REPLACED text]
      When just searching, the non-interesting matches will be notified as an empty match and the correct matches will be notified as selected text.
      And if a global replacement occur, with the Replace All button, this regex would just replace the same occurrences as with the (*SKIP)(*F) method !
      Try against your INPUT text, pasted in a new tab : you should get 2 empty matchs and 4 selected range of characters. And, after replacement you’ll left with four zones [REPLACED text].
      <html>
      <p style="font-family: &quot;verdana&quot;; font-size: 18px; color: black; line-height: 18px; text-align: justify; font-style: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-indent: 0px; text-transform: none; white-space: normal; widows: 2; word-spacing: 0px; background-color: cyan;"><span style="font-size: 13.5pt; font-family: &quot;Verdana&quot;,&quot;sans-serif&quot;;"><code style="background-color: transparent;">•••••<b>some text here</b></code></span></p>
      <span><span style="font-size: 13.5pt; font-family: &quot;Verdana&quot;,&quot;sans-serif&quot;; background-color: cyan;"><code style="background-color: transparent;"><b>some text here</b></code></span>
      <p style="font-family: &quot;verdana&quot;; font-size: 18px; color: cyan; line-height: 18px; text-align: justify; font-style: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-indent: 0px; text-transform: none; white-space: normal; widows: 2; word-spacing: 0px; background-color: cyan;"><span style="color: black; font-size: 13.5pt; font-family: &quot;Verdana&quot;,&quot;sans-serif&quot;;"><code style="background-color: transparent;">•••••<b>some text here</b></code></span></p>
      <p style="font-family: &quot;verdana&quot;; font-size: 18px; color: cyan; line-height: 18px; text-align: justify; font-style: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-indent: 0px; text-transform: none; white-space: normal; widows: 2; word-spacing: 0px; background-color: navy;"><span style="font-size: 13.5pt; font-family: &quot;Verdana&quot;,&quot;sans-serif&quot;;"><code style="background-color: transparent;"><b>some text here</b></code></span></p>
      </html>
      Now, it’s not the end of the story ! Imagine that, against the same INPUT text, below :
      We use this simplified regex S/R :
      FIND (?-is)ABC\KDEF|(DEF)
      REPLACE ?{1}12345
      Note that, this time, the \K is placed before the string DEF
      So, it would match any string DEF, whatever it’s preceded or NOT by the ABC string
      But, due to the group, in the final part of the regex and due to the conditional replacement, We would get this new OUTPUT text, after a click on the Replace All button
      12345  ABC   ABC     12345  ABC   XYZ12345   ABC
      • if DEF is preceded by ABC, it replaces the string ABCDEF by the string ABC
      This S/R is a variant of the previous one which may interest you in some cases !
      In short, I cannot imagine, presently, other methods than the two above, with (SKIP)(*F) or \K
      Remember, that the look-arounds structure does not seem appropriate to your style of search !
      dr ramaanandD 1 Reply Last reply Reply Quote 1
      • dr ramaanandD Offline
        dr ramaanand @guy038
        @guy038 Oui, merci beaucoup!
        dr ramaanandD 1 Reply Last reply Reply Quote 0
          dr ramaanand @dr ramaanand
