    v7.5.2 of N++ will not launch
    7.5.2 launch
    14 Posts 2 Posters 6.5k Views 2 Watching
    • no9onN Offline
      no9on
      I’m sure that this related to something on my system, however, the latest N++ 7.5.2 has incorporated something in its code that prevents it from launching. Everything perfectly normal prior to this update.
      The changes may be perfectly valid for the majority, but something is definitely being implemented differently now.
      Note: Notepad++ 7.5.2 does not show up in Taskmgr and there are no error codes.
      Win 7N Pro x86
        Claudia Frank @no9on
        @no9on
        Did you try to start npp from the shortcut or by double clicking exe file
        or by using context menu in explorer view? Or something different?
        Did you check windows event log?
        • no9onN Offline
          no9on
          Thank you for the reply.
          Sorry, I should have included the Windows Event log earlier.
          These were started by direct exe clicking:
          Faulting application name: notepad++.exe, version: 7.5.2.0, time stamp: 0x5a1b4b1f
          Faulting module name: notepad++.exe, version: 7.5.2.0, time stamp: 0x5a1b4b1f
          Exception code: 0xc0000005
          Fault offset: 0x00092892
          Faulting process id: 0x990
          Faulting application start time: 0x01d3688d8c9e054e
          Faulting application path: D:\Notepad++\notepad++.exe
          Faulting module path: D:
          Report Id: ca74e2e6-d480-11e7-bd2b-001cc08d5b1c
          Fault bucket , type 0
          Event Name: APPCRASH
          Response: Not available
          Cab Id: 0
          Problem signature:
          P1: notepad++.exe
          P2: 7.5.2.0
          P3: 5a1b4b1f
          P4: notepad++.exe
          P5: 7.5.2.0
          P6: 5a1b4b1f
          P7: c0000005
          P8: 00092892
          P9:
          P10:
            @no9on
            Does not give any additional info, unfortunately.
            Did you try to start as normal user and using “run as administrator”?
            Behave both the same?
            The error 0xc0000005 itself points to accessing memory location which isn’t
            allowed as owned by other application, system …
            You did install the 32bit version did you? Btw. what version is Win 7N Pro x86?
            Have you tried to deinstall, clean directory, reboot and install it again?
            • no9onN Offline
              no9on
              Running as administrator. User has admin rights also.
              Using the 7z x86 (32-bit) version.
              Installed to different drive, new folder.
              I appreciate the help and recognize that this is something on my side that needs to be resolved, BUT since all previous versions and updates prior to today ran w/o a problem, and I haven’t added any apps or hardware recently; there must be some implementation of the code which is different for this update. Memory resources haven’t changed.
              Also, Win 7N (also true for 10N) is a European version (running for several years) that comes w/o IE and the windows media player apps. It was produced after MS was sued by European Union interests to separate out those functions which are normally deeply integrated into the OS.
                @no9on
                can you double check the size of the exe and scintilla dll
                2599088 Nov 27 01:36 notepad++.exe
                1052848 Nov 27 01:36 SciLexer.dll
                Note, I’m using the zip version but the sizes must be the same.
                Thx, for clarification - wasn’t aware of it although I live in Europe.
                • no9onN Offline
                  no9on
                  Everything seems to check.
                  notepad++.exe -> (2,599,088 bytes)
                  SciLexer.dll -> (1,052,848 bytes)
                  Again, it has to be in the code itself. Since the developer would probably have to partially reverse whatever changes were made, one-by-one, I will have to make this an EOL for me.At some point, I will re-install the OS, but for the moment, since everything else is functioning, I will postpone that.
                  Thank you so much for your time.
                    @no9on
                    if you don’t mind one final suggestion.
                    Download procmon from sysinternals.
                    Run it and create a filter process name is notepad++.exe
                    Apply it
                    In main procmon gui press the icon which is named something like
                    process and threads (one of the last ones)
                    Start npp
                    Now you should see some infos coming in - are there any useful informations
                    which could indicate what your problem is?
                    • no9onN Offline
                      no9on
                      I certainly don’t mind any suggestions.
                      So, I ran procmon with the notepad++.exe filter for both the 7.5.2 version and the 7.5.1 version. Since the 7.5.1 version works, it has a much longer output log. There is a lot to go through and it will take me a good long time to see if I can make anything out of it, but I do have a preliminary catch.
                      I am comparing the two outs and the first instance of a difference seems to be a Load Image operation. This particular operation occurs with v7.5.2. The path is:
                      “…\Windows\System32\api-ms-win-core-synch-l1-2-0.dll”
                      The result for the operation says Success. Not sure why v7.5.1 did not have this operation at the same process location. The api-ms-win-core-synch-l1-2-0.dll type files are part of the VC++ 20xx redistributables.
                      Note: I ran the exe with four of the filter options, including Registry, File System Activity, Process and Threads, and Network (though I’m not on a LAN).
                      Thank you for the suggestion Claudia.
                        @no9on
                        as npp doesn’t show up I assume it crashes during image load. Don’t you see any error there?
                        A success means it was able to load it, so it can’t be the reason for the issue you encountered.
                        • no9onN Offline
                          no9on
                          OK, I isolated just the file system activity. The VC++ dll operations, even though they show success in loading, are only present in the latest, v7.5.2 version - and, calling them is the last step prior to failure to error reporting.
                          N++ v7.5.2
                          J:\Windows\System32\Wldap32.dll
                          J:\Windows\System32\uxtheme.dll
                          J:\Windows\System32\api-ms-win-core-file-l2-1-1.dll
                          Thread Create
                          Thread Create
                          J:\Windows\System32\api-ms-win-core-sysinfo-l1-2-1.dll
                          J:\Windows\system32\WerFault.exe
                          J:\Windows\System32\apphelp.dll
                          crash
                          N++ v7.5.1
                          Thread Create
                          Thread Create
                          J:\Windows\System32\WindowsCodecs.dll
                          J:\PortableApps\Notepad++\plugins\ccc.dll
                          J:\Windows\System32\version.dll
                          J:\Windows\System32\oleacc.dll
                          J:\Windows\System32\winspool.drv
                          J:\Windows\System32\winmm.dll
                          J:\Windows\System32\olepro32.dll
                          success
                            Claudia Frank
                            What are the actions (File, Process and Registry) just before
                            as this is the time when windows jumps in to collect information to report the issue.
                            Any errors just before this call?
                            • no9onN Offline
                              no9on
                              This includes Registry calls and File System activity leading up to WerFault.exe. Some repetitive registry keys may not be shown. The v7.5.1 is shown in the same spot for comparison.
                              There are definite differences, omissions, and additions to the two groups of apps with both file and registry processes.
                              N++ v7.5.2
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DllNXOptions\WLDAP32.dll
                              HKLM\System\CurrentControlSet\Services\LDAP
                              HKLM\Software\Microsoft\Rpc\Extensions
                              HKLM\SOFTWARE\Microsoft\Rpc\Extensions\NdrOleExtDLL
                              HKCU\Software\Classes
                              HKLM\SOFTWARE\Microsoft\Rpc\MaxRpcSize
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DllNXOptions\uxtheme.dll
                              HKLM\System\CurrentControlSet\Control\ComputerName\ActiveComputerName
                              HKLM\System\Setup
                              HKLM\SYSTEM\Setup\OOBEInProgress
                              HKLM\SYSTEM\Setup
                              HKLM\System\Setup
                              HKLM\SYSTEM\Setup\SystemSetupInProgress
                              HKLM\SYSTEM\Setup
                              HKLM\Software\Policies\Microsoft\Windows NT\Rpc
                              HKLM\Software\Policies\Microsoft\SQMClient\Windows
                              HKLM\SOFTWARE\Policies\Microsoft\SQMClient\Windows
                              HKLM\SOFTWARE\Policies\Microsoft\SQMClient\Windows\CEIPEnable
                              HKLM\Software\Policies\Microsoft\Windows\System
                              HKLM\SOFTWARE\Policies\Microsoft\Windows\System
                              HKLM\SOFTWARE\Policies\Microsoft\Windows\System\CopyFileBufferedSynchronousIo
                              Thread Create
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume{423c6661-cfca-11e7-b7e1-806e6f6e6963}
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume{423c6661-cfca-11e7-b7e1-806e6f6e6963}\Data
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume{423c6661-cfca-11e7-b7e1-806e6f6e6963}\Generation
                              Thread Create
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume{2e1971d0-82c9-11e5-a7f7-806e6f6e6963}
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume{2e1971d0-82c9-11e5-a7f7-806e6f6e6963}\Data
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\CPC\Volume{2e1971d0-82c9-11e5-a7f7-806e6f6e6963}\Generation
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WerFault.exe
                              HKLM\System\CurrentControlSet\Control\Session Manager\AppCertDlls
                              HKLM\System\CurrentControlSet\Control\SafeBoot\Option
                              HKLM\Software\Policies\Microsoft\Windows\Safer\CodeIdentifiers
                              crash
                              N++ v7.5.1
                              HKLM\Software\Microsoft\Windows NT\CurrentVersion\Time Zones\Pacific Standard Time\Dynamic DST
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones\Pacific Standard Time\Dynamic DST\FirstEntry
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones\Pacific Standard Time\Dynamic DST\LastEntry
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones\Pacific Standard Time\Dynamic DST\2015
                              HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Time Zones\Pacific Standard Time\Dynamic DST\2007
                              Thread Create
                              Thread Create
                              HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2{bb600dfd-cdb4-11e7-9b8d-806e6f6e6963}
                              HKLM\System\CurrentControlSet\Control\Nls\Locale
                              HKLM\System\CurrentControlSet\Control\Nls\Locale\Alternate Sorts
                              HKLM\System\CurrentControlSet\Control\Nls\Language Groups
                              HKLM\System\CurrentControlSet\Control\Nls\Locale\00000409
                              HKLM\System\CurrentControlSet\Control\Nls\Language Groups\1
                              success
                                @no9on
                                sorry, unfortunately nothing which makes me think this could be the problem.
                                Btw. the tests were done with clean npp setup, means no additional plugins used, correct?
